Hi Erwin,
At the step 2) when you say: "(change remote:remote to your credentials and change ipaddress to your ip address and add a port if needed)" is the "Remote:remote" the user:password of logic machine? and another question: is the ipadress the local one (i.e. 192.168...) of the logic Machine or the DNS server?
At the 3) step, when you say: "Create a event based script to trigger the IFTTT Maker recipe like this:....", I guess we have to do it on the LM configuration at scripting thumbnail , right?.
In that case how can we know that the url: url = \https://maker.ifttt.com/trigger/' .. is the correct one? I do not know what the trigger is on the IFTTT applet in order to write it correctly on the event based script on LM scripting thumbnail.
Could you give some further/detailed information at how to make the 3) step correctly? Additionally, I would like to know where to find the Maker_Secret_Key on the created IFTTT applet at 1) and 2) stepMany thanks in advaced and thank you for your kind support.Best regards.
I send you my best regards and many thanks in advanced.
Erwin van der Zwart Wrote:
You can use IFTTT in combination with the Maker Channel (bi-directional)
You have to enable the remote services in the controller (see controller manual) to receive commands and we need a script to send commands to IFTTT.
1) Create a Maker recipe with a unique trigger (for this example) "this_is_my_trigger_unique_event"
2) Create inside your recipe a action like: "http://remote:remote@ipadress/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=write&alias=0/0/1&value=true" and
select method "get" and select content type "text / plain" body can be left empty. (change remote:remote to your credentials and change ipaddress to your ip address and add a port if needed)
3) Create a event based script to trigger the IFTTT Maker recipe like this:
-- *************************************** START OF SCRIPT ************************************* --
-- *********** If This Then That Maker Channel Trigger Event Version 1.0 Created by Erwin van der Zwart ********* --
-- *************************************** SET PARAMETERS ************************************* --
-- Set your personal secret key from received https://maker.ifttt.com
Maker_Secret_Key = 'PUTHEREYOURPERSONALMAKERKEY'
-- Unique trigger event name you have set in the 'Maker' recipe 'This' event
Maker_Event_Name = 'this_is_my_trigger_unique_event' -- Have to match your trigger description you have set in the recipe
-- *************************************** END PARAMETERS ************************************* --
local https = require 'ssl.https'
function iftttmaker(Maker_Secret_Key, Maker_Event_Name)
local r, c, h, s = https.request{
url = 'https://maker.ifttt.com/trigger/' .. Maker_Event_Name .. '/with/key/' .. Maker_Secret_Key,
sink = ltn12.sink.table(resp),
protocol = "tlsv1"
return r, c, h, s
r, c, h, s = iftttmaker(Maker_Secret_Key, Maker_Event_Name)
-- ****************************************** END SCRIPT **************************************** --
Good luck!
Best Regards,
Erwin van der Zwart
protocol = "tlsv1"
return r, c, h, s
Good luck!
Best Regards,
Erwin van der Zwart
