Bacnet server and Client
#26
(13.08.2018, 06:53)admin Wrote: Why do you use BACnet to communicate between LMs when you can use KNX/IP? There might be a loop between LMs - you send value via BACnet, it gets sent back via KNX/IP, this triggers the script again. LM will reboot automatically when it runs out of memory which can happen when there are a lot of active running scripts.
Only for test purposes, I have checked that there is no connection on KNX ip. I have used Virtual Objects also.
Ok, I see. but why does my script and objects disappear?
Bacnet server and Client - by Evens - 06.07.2018, 12:33
RE: Bacnet server and Client - by edgars - 06.07.2018, 13:29
RE: Bacnet server and Client - by Evens - 06.07.2018, 17:32
RE: Bacnet server and Client - by Evens - 09.07.2018, 19:37
RE: Bacnet server and Client - by Evens - 10.07.2018, 18:11
RE: Bacnet server and Client - by Evens - 10.07.2018, 21:57
RE: Bacnet server and Client - by Daniel - 11.07.2018, 07:18
RE: Bacnet server and Client - by Evens - 11.07.2018, 08:21
RE: Bacnet server and Client - by Evens - 07.08.2018, 06:10
RE: Bacnet server and Client - by admin - 07.08.2018, 06:18
RE: Bacnet server and Client - by Evens - 07.08.2018, 06:23
RE: Bacnet server and Client - by admin - 07.08.2018, 09:18
RE: Bacnet server and Client - by Evens - 07.08.2018, 10:26
RE: Bacnet server and Client - by admin - 07.08.2018, 10:36
RE: Bacnet server and Client - by Daniel - 07.08.2018, 10:39
RE: Bacnet server and Client - by Evens - 07.08.2018, 13:01
RE: Bacnet server and Client - by Daniel - 07.08.2018, 14:01
RE: Bacnet server and Client - by Evens - 08.08.2018, 06:56
RE: Bacnet server and Client - by Evens - 13.08.2018, 06:32
RE: Bacnet server and Client - by admin - 13.08.2018, 06:53
RE: Bacnet server and Client - by Evens - 13.08.2018, 07:00
RE: Bacnet server and Client - by admin - 13.08.2018, 07:31
RE: Bacnet server and Client - by Evens - 13.08.2018, 08:48
