Problems with some Modbus data in Logic Machine
Value_nan and value_default won't work for you. First is for array and second when you can't read register. Probably the easiest will be the script. value_custom is the closest but only if you have predefined values.
When you specify modbus datatype then LM knows what to do with it. If you don't specify it assume it is single register.
RE: Problems with some Modbus data in Logic Machine - by Daniel - 23.08.2018, 15:19
