SNMP protocol in Logic Machine
Here's a universal solution for reading from multiple SNMP peers. Create a resident script with sleep time > 0, adjust devices table as needed. You have to fully restart the script via enabled/disable when changing anything in devices table.
if not devices then   require('snmp')   devices = {     {       ip = '192.168.1.1',       mapping = {         { oid = '1.3.6.1.2.1.1.1.0', addr = '8/0/0' },         { oid = '1.3.6.1.4.1.14988.1.1.1.3.1.4.6', addr = '8/0/1' },       }     },     {       ip = '192.168.1.4',       mapping = {         { oid = '1.3.6.1.4.1.14988.1.1.3.8.0', addr = '8/0/0' },         { oid = '1.3.6.1.4.1.14988.1.1.3.10.0', addr = '8/0/1' },       }     },   } end for _, dev in ipairs(devices) do   local conn, err = snmp.open({     version = snmp.SNMPv1,     community = 'public',     port = dev.port or 161,     peer = dev.ip,   })   if conn then     for _, map in ipairs(dev.mapping) do       local res, err = conn:get(map.oid)       if res and res.value ~= nil then         grp.checkwrite(map.addr, res.value)       else         alert('SNMP read from %s %s failed (%s)', dev.ip, map.oid, tostring(err))       end     end     conn:close()   else     alert('SNMP connection to %s failed (%s)', dev.ip, tostring(err))   end end
As for traps and SNMP v3 - we'll look into it later on.
RE: SNMP protocol in Logic Machine - by AEK - 04.09.2018, 09:17
RE: SNMP protocol in Logic Machine - by AEK - 06.09.2018, 06:59
RE: SNMP protocol in Logic Machine - by admin - 06.09.2018, 07:57
RE: SNMP protocol in Logic Machine - by admin - 07.09.2018, 07:00
RE: SNMP protocol in Logic Machine - by admin - 11.09.2018, 06:41
RE: SNMP protocol in Logic Machine - by AEK - 11.09.2018, 09:26
RE: SNMP protocol in Logic Machine - by admin - 12.09.2018, 05:58
RE: SNMP protocol in Logic Machine - by admin - 15.10.2018, 18:10
RE: SNMP protocol in Logic Machine - by admin - 16.10.2018, 10:30
RE: SNMP protocol in Logic Machine - by admin - 16.10.2018, 17:50
RE: SNMP protocol in Logic Machine - by admin - 11.04.2019, 09:52
RE: SNMP protocol in Logic Machine - by admin - 17.06.2019, 07:34
RE: SNMP protocol in Logic Machine - by admin - 17.06.2019, 08:34
RE: SNMP protocol in Logic Machine - by admin - 18.06.2019, 08:05
RE: SNMP protocol in Logic Machine - by admin - 11.07.2019, 08:48
RE: SNMP protocol in Logic Machine - by admin - 12.07.2019, 06:15
RE: SNMP protocol in Logic Machine - by admin - 04.11.2019, 12:12
RE: SNMP protocol in Logic Machine - by admin - 21.02.2020, 08:22
RE: SNMP protocol in Logic Machine - by admin - 06.03.2020, 12:26
RE: SNMP protocol in Logic Machine - by admin - 06.03.2020, 18:47
RE: SNMP protocol in Logic Machine - by admin - 07.03.2020, 13:20
RE: SNMP protocol in Logic Machine - by admin - 09.03.2020, 09:21
RE: SNMP protocol in Logic Machine - by admin - 28.03.2020, 15:06
RE: SNMP protocol in Logic Machine - by admin - 12.04.2020, 12:12
RE: SNMP protocol in Logic Machine - by admin - 15.04.2020, 06:08
RE: SNMP protocol in Logic Machine - by admin - 09.12.2020, 07:07
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 13:15
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 13:34
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 14:22
RE: SNMP protocol in Logic Machine - by admin - 19.09.2022, 13:00
