Threads: 29
(12.11.2024, 14:11)Dmitry.T Wrote: Thanks Daniel.
Is there any chance to gain full control over this bulb?
This is question to light manufacture but answer will be no.
Threads: 45
@stianj, enable debug logging in ZigBee app then reset and pair your lamp again. Send the logs afterwards.
Threads: 1
Hello all,
It seems that my zigbee library is missing in my device
How can I find the library and add it?
Resident script:3: module 'applibs.zigbee' not found:
no field package.preload['applibs.zigbee']
no file './applibs/zigbee'
no file 'Library applibs/zigbee'
no file 'Library applibs/zigbee.so'
no file 'Library applibs.so'
Threads: 29
Which firmware and hardware do you use?
Threads: 1
HW: Wiser for KNX (i.MX6) v3
SW: 3.0.0
Threads: 29
Did you install the app?
Threads: 1
KNX Hybrid (0.1.9) installed. And I already have 45 devices running.
I tested this library before and it was working but seems it is not there now.
Threads: 29
Uninstall it and install again but it sound like you have some data corruption.
Threads: 1
Will I lose all my Zigbee installation?
Threads: 29
You should not but make yourself a backup. If data is corrupted it is hard to say what will happen. Is everything else working correctly?
Threads: 1
Everything else is working properly
How can I investigate if there is data corruption or not?
Threads: 2
is Wiser Smoke Alarm Battery CCT599002 Supported ?
Threads: 29
We support this, but SE tend to have same devices under different names. Ask SE if it is the same.
Schneider Electric W599001 Schneider Electric - Wiser Smoke Alarm
Schneider Electric W599501 Schneider Electric - Wiser Smoke Alarm
Threads: 2
Thank you Daniel,
i try it out an give Feedback if it was succsessfull or not
Threads: 7
19.11.2024, 12:57
(This post was last modified: 19.11.2024, 12:58 by Erwin van der Zwart.)
W599001 Schneider Electric - Wiser Smoke Alarm = Battery powered version
W599501 Schneider Electric - Wiser Smoke Alarm = Mains 230V powered version
Threads: 45
Have you done reset and pair procedure after updating the app?
