30.07.2025, 14:45
(30.07.2025, 10:27)Daniel Wrote: New update is here
https://forum.logicmachine.net/showthrea...6#pid39496
Cloud for Visu is working there.
Small mistake in the download links
2024, if i change it to 2025 it works
Open beta testing
30.07.2025, 14:45
(30.07.2025, 10:27)Daniel Wrote: New update is here Small mistake in the download links 2024, if i change it to 2025 it works
is possible somehow Mosaic visu convert/import to new visu solution or new visualization simply should be created from zero? I have some sites with mosaic and now question what to do because I will need some mosaic modernization in future, but of course good to use latest fw with mistakes correction.. BR, Alex
31.07.2025, 06:56
There is no conversion tool, Mosaic as it is will stay for longer.
31.07.2025, 08:31
31.07.2025, 08:51
Import/export of plans/layouts and custom widgets is planned.
01.08.2025, 13:45
I have many questions, but will try and contain myself and keep the posts relatively short with few questions at a time.
I have lots of custom js in the old visu. I would love some examples how to do some things in the new visu. As an example I would like to use Chartist in new visu as well... Secondly, I love the new widgets for light and movement - but I would really like to be able to input a percentage directly. Like, when I click the percentage I can input a number that will be sent to an object. Like if I have many blinds in the same room, and I want them all to be the same height, it's difficult to maintain that with the slider. Last - the temperature widget. It would be very nice if it could implement the "setpoint shift" that is very common in KNX. I don't know if that is common with other vendors, but at least with Gira there is an object called "heating message" (or "cooling message") that tells if a thermostat is actually heating or cooling. Would be good if we could have that in the thermostat as well, showing the temperature (or some icon?) with red or blue color. Fan coil options identical to thermostat in Mosaic would finish it off as perfect! Thoughts?
04.08.2025, 08:24
We will provide more JS examples soon.
As for the widgets, we will add much more later on. If you want something specific, here is the place to describe it: https://forum.logicmachine.net/showthread.php?tid=5875
04.08.2025, 10:31
Ok, thank you
Sorry for polluting this thread with widgets, will make a new post soon.But ok, two other issues: 1: The "Additional values / icons" - when I "Load object custom values" it does not work - the field get populated, but they don't show in visu. If I change them manually, they show up... 2: Iframe; In tile view it should be possible to define size differently. the close button gets out of reach very fast - unless the frame will be very small in plan view... And it would be nice if I could choose to have it open automatically in tile view as well, just as in plan view...
04.08.2025, 10:54
1. Share your object custom value configuration.
2. Share your backup as not sure what sizes you are trying to use. Why would you want to have frame opened in Tile?
04.08.2025, 22:01
Thanks for your reply
![]() 1: I'm not sure what you need here? 2: I can share backup, but I don't think it's needed. I want to show eventlog.lp also in tile view. In order to be able to close the iframe in tile view on my phone in portrait mode it has to be much more narrow than what woud make sense in plan view. When I'm now writing I understand that I should probably use two iframes - one that is visible in tile and another in plan with different sizes... But it would still be better if I could show the iframe when I open the plan without having to click the icon...
06.08.2025, 12:10
You can use HTML widget to display iframe in both plan and tile view. But in this case you won't be able to automatically refresh the iframe periodically.
Code: <iframe class="w-100 h-100" src="/user/data.lp">We have plans to implement a more advanced alert/event system with Visu integration later.
08.08.2025, 09:28
Thanks admin - that will do for now
![]() One last question before the weekend... When uploading custom icons you can't change their colour... I would expect that to work for SVG-icons at least?
08.08.2025, 11:19
Custom icons cannot be placed the same way as built-in icons so colors cannot be changed.
Maybe you can find icons you need in the Font Awesome library. If so then let us know which icons to add.
08.08.2025, 16:19
(06.08.2025, 12:10)admin Wrote: You can use HTML widget to display iframe in both plan and tile view. But in this case you won't be able to automatically refresh the iframe periodically. Hi admin, this soluction it is only for local use, is It? Best regards Cristian
11.08.2025, 07:35
Local iframe won't work over cloud connection.
11.08.2025, 07:40
11.08.2025, 07:43
Custom apps will not work over our cloud.
11.08.2025, 07:52
13.08.2025, 10:28
New update is here
https://forum.logicmachine.net/showthread.php?tid=6079 New trend widget is created where you can use LM trends and configure them into nice single widget. Camera snapshot was added, similar to the Mosaic version where you can grab image from the camera and refresh it to make it look like a video. We also added local proxy where LM is processing the image, thanks to this we don't have the issue of browser blocking simple authentication. Obviously this adds extra load to LM so use this with care. The image will be also visible via cloud.
Ctrl+F5 |
« Next Oldest | Next Newest »
