Alert Manager
#81
You can check the structure of the Alerts manager data using the Storage viewer app. But if you modify this data via a script the client won't see these changes unless a reload is performed.
It's only possible when the alert manager is loaded into an frame in the visu by using this custom JS:
1234567891011121314
$(function(){    $(document).ready(function() {       var f= $('iframe');       f.load(function(){          if (typeof grp != 'undefined') {             grp.listen('1/1/1', function(object, state) {                if (state == 'value' && object.value == true ){                   f.contents().find('#AcknowledgeButton').click();                }             }, true);           }       });    }); });
Hi, I have used this app in the past but I have noticed that I have no more access to this alert manager in Schneider Spacelynk.
Where could I find the latest version of this app ?
Thank you
https://forum.logicmachine.net/showthrea...3#pid22783
I have written this script for surveillance of alarms. It will only generate one alarm if an Object is not updated within a range of time. You can use it as Resident or Scheduled Script. It takes every object with the tag "Alarm". Change the "controlltime" to your desire.
12345678910111213141516171819202122232425262728293031323334353637383940414243444546
--This script is for Object surveillance passivley with the updatetime property --Alarms will be updated on change! alarms = grp.tag('Alarm') --add the Tag or Tags of the Object that need surveillance controlltime = 30 --Allowed Time between recieved Telegramms in Seconds --initializing Tables for Alarming currentstate = {} previousstate = storage.get("previousstate") or {} now = os.time() --Iteration throgh the alarms Table to get the update time of every Object for index, alarm in ipairs(alarms) do     lastrecieved = alarm.updatetime     local online     --calculating the Timedelta and comparing it with our Variable     if (now - lastrecieved) > controlltime then         online = false     else         online = true     end     -- Store the current status in the currentstatus table     currentstate[alarm.id] = {id = alarm.id, comment = alarm.comment, online = online}     -- Compare the current status with the previous status     if previousstate[alarm.id] == nil or currentstate[alarm.id].online ~= previousstate[alarm.id].online then         if not currentstate[alarm.id].online then             alert("Alarm " .. currentstate[alarm.id].comment .. " nicht verfügbar")           else                   alert("Alarm " ..currentstate[alarm.id].comment .. " verfügbar")         end     end end -- Log the current status -- log(currentstate) -- Save the current status to persistent storage as previous status storage.set("previousstate", currentstate)
And this script that will actively send a read request to check if alarms are still available. It will take every objekt with the tag "Alarm". This is designed to be used as resedent or scheduled script.
-- Variables as Tag alarms = grp.tag('Alarm') currentstatus = {} previousstate = storage.get("previousstate") or {} -- Iterate over all alarms for index, alarm in ipairs(alarms) do     value, responding = grp.readvalue(alarm.address, readtimeout)     local online     if responding == "timeout" then         online = false     else         online = true     end     -- Store the current status in the currentstatus table     currentstatus[alarm.id] = {id = alarm.id, name = alarm.name, online = online}     -- Compare the current status with the previous status     if previousstate[alarm.id] == nil or currentstatus[alarm.id].online ~= previousstate[alarm.id].online then         if not currentstatus[alarm.id].online then             alert("Alarm " .. currentstatus[alarm.id].name .. " nicht verfügbar")         end     end end -- Log the current status --log(currentstatus) -- Save the current status to persistent storage as previous status storage.set("previousstate", currentstatus)
