Threads: 36
Is there any list of products your LM Reactor Lite's CAN FT supports?
Currently it would be great if someone shares thermo/hydro/air quality/motion/etc. sensors with CAN FT.
And when KNX-CAN gateway will be available?
Threads: 36
So, any sensors you want to suggest are available only by your Universal canX bus IO module 16 AI/DO ?
And what about any third party devices? Where I can find them compatible with LM? not car devices.
Threads: 0
Looks good! canT wait to try some of these devices. How open is the protocol/interface for 3rd party hardware developers?
Threads: 99
after we will stabilize the specification (there might be some small changes compared to current stage), we will publish it. You would be able to edit and add your product specification / product description files. At first stage we will be approving them before including. The configuration is made as application platform, there is access to all DB structure, API / functions. Its possible to write your own apps to communicate with canX.
Threads: 87
Hi. I periodically looking through new devices/protocols. CanX and new devices looks very interesting, but my opinion - here is missing out implementation of audio. Not voice control, it could be done by other ways. I mean audio implementation in wall switches/devices/controllers. It could be small mp3 module with amplifier and control over KNX/CanX and possibility to preload/load mp3 audiofiles by request.. Where it can be used?? Voice alerts, setting confirmation, alarm clocks... I am not speaking about smart audio like stream players. I heard that as example Honeywell has fire alarm detector with voice alert, can be interesting. Just my opinion..
Threads: 161
Audio or simple radio would be also another advantage of this solution.
Done is better than perfect
Threads: 99
thanks for the suggestion. We will work on simple audio solution for canX.
Threads: 0
Has the wall mounted canX sensor platform been released? Having a CanX touch button would be really nice.
Are there any CanX wall-mounted light switches to control lighting within a room?
Thank you, Martin.
