LM4 storage capacity
Here in a project, we are using LM4 for DMX control having 1500 DMX channels. We need to run a sequence of 5 minutes in infinite loops. So, is in-built storage of LM4 is sufficient or need to use some external data storage into USB slots. If yes, please specify the capacity.
As given in system status of LM4's web-console, in-built storage is 125MB.
If you have a pre-defined sequence with 1500 channels then you need to use a different approach, as storage requests will take too much time to provide a smooth transition. The best way would be to create a table of states for each channel for each time slot (10 seconds, for example). I can give some more advice if you can specify how the sequence should behave.
Following is the video link - https://drive.google.com/file/d/0B1XFdzf...ef=2&pli=1
Please check and let me know how to create table of states.
Looks great!
Can you please ask the designer of this project to make a table which will define which channels for how long should have which color? And so with all other time slots and channels.
(04.03.2016, 08:39)s.prathmesh Wrote: Following is the video link - https://drive.google.com/file/d/0B1XFdzf...ef=2&pli=1
wow, nice project
Here is the script (predefined-scene) for operating DMX objects on 3 x RS-485 interfaces of LogicMachine4. Add resident script, sleep time = 0.
Big steps are defined as VALUES. RESOLUTION is a count of small steps between big steps - defines how smooth one color transits into other.  STEPDELAY defines what is delay between each small step.
Approximate time:
BIG STEP TIME = RESOLUTION * (STEPDELAY + 0.1)
if not values then  luadmx = require('luadmx')  -- channel values for each second for each output port  values = {    -- second 1    {      -- port 1      { 0, 127, 255 },      -- port 2      { 255, 255, 0 },      -- port 3      { 255, 0, 0 },    },    -- second 2    {      -- port 1      { 255, 255, 0 },      -- port 2      { 0, 127, 255 },      -- port 3      { 255, 0, 255 },    },    -- second 3    {      -- port 1      { 0, 127, 255 },      -- port 2      { 255, 0, 0 },      -- port 3      { 255, 255, 127 },    },  }  -- number of step, must be tuned manually  resolution = 10  -- sleep between steps, must be tuned manually  stepdelay = 0.05  -- list of ports to use  ports = {    '/dev/RS485-1',    '/dev/RS485-2',    '/dev/RS485-3',  }  function init(port, count)    local ctx, err = {}    -- init dmx    ctx.dm, err = luadmx.open(port)    if not ctx.dm then      error('Port ' .. tostring(port) .. ' error: ' .. tostring(err))    end    -- channel count    ctx.count = count    ctx.dm:setcount(count)    -- reset channel map    ctx.values = {}    ctx.deltas = {}    -- fill channel map    for chan = 1, count do      ctx.values[ chan ] = 0      ctx.dm:setchannel(chan, 0)    end    ctx.dm:send()    return ctx  end  function set(ctx, values, resolution)    local value, delta    -- check for new values for each channel    for chan = 1, ctx.count do      value = values[ chan ] or 0      ctx.deltas[ chan ] = (value - ctx.values[ chan ]) / resolution      ctx.values[ chan ] = value    end    ctx.ticks = resolution  end  function step(ctx)    local ticks = ctx.ticks - 1    -- transition for each channel    for chan = 1, ctx.count do      local delta = ctx.deltas[ chan ]      if delta ~= 0 then        local value = ctx.values[ chan ] - ctx.deltas[ chan ] * ticks        ctx.dm:setchannel(chan, value)      end    end    ctx.dm:send()    ctx.ticks = ticks  end  ctxlist = {}  for i, port in ipairs(ports) do    ctxlist[ i ] = init(port, #values[ 1 ][ i ])  end end for sec, secvalues in ipairs(values) do  for id, ctx in ipairs(ctxlist) do    set(ctx, secvalues[ id ] or {}, resolution)  end  for i = 1, resolution do    for id, ctx in ipairs(ctxlist) do      step(ctx)    end    os.sleep(stepdelay)  end end
