(26.11.2018, 11:56)Daniel. Wrote: Hi
Can you explain your problem, it is not clear from your description.
Of course,
I'm sorry if I did not explain myself.
The controls of the system (as can be seen in the attached image) as the change in the display of text value in a variable, to have the resolution so large, it comes out too small, and this is the problem.
(26.11.2018, 12:16)Daniel. Wrote: Hi
Did you select this option?
Yes, I have tried it in both ways, selecting and without selecting and the result is the same ...
Please send my your backup to PM.
Thank you very much for your help, the visualization created for this client is confidential and they do not allow me to show it.
I am doing modified DIV tests using custom CSS and I have managed to make the letter bigger, although the text container is still small ...
I'll keep doing tests until I get it right. If someone has more experience with these modifications, I would be grateful for your help.
30.11.2018, 11:45 (This post was last modified: 30.11.2018, 11:47 by AEK.)
