03.12.2018, 13:00
I've found that when I've change ga which is connected to coil and coil should be updated then its not updated to show its current value.
E.g.
I have writable coil for vacuum-cleaner mode status in recuperator. When I try to switch-off it from modbus while relay switch is closed then LM in mapper shows updated status(is off) but I know that this is not true and also when I try read coil value by LM Read test then it returns that vacuum-cleaner mode is on.
E.g.
Done is better than perfect
