Threads: 39
IS it planned to develop Obix gateway like you did with Bacnet ?
What do you think about it.
SE ECO EXPERT
Threads: 100
by our information people are not using Obix too widely. You can realize same tasks on web services.
Maybe you can provide your arguments why it is worth to add support of Obix?
Thanks!
Threads: 39
no it was just a question, because I readed this:
http://www.knx.org/fileadmin/downloads/0...ebsite.pdf
And in this doc, Obix looks more open... It was just in order to have your though
SE ECO EXPERT
Threads: 7
(03.03.2016, 10:00) domotiqa Wrote: no it was just a question, because I readed this:
Hi Domotiqa,
Here are 2 functions i use to communicate with our SmartStruxure Lite controller with oBIX. Maybe you can use it.
-- function to get data from mpm
function get_data_from_mpm(mpm_settings,object,item)
local url = "http://" .. mpm_settings.username .. ":" .. mpm_settings.password .. "@" .. mpm_settings.ip .. "/obix/network/" .. mpm_settings.node .. "/DEV" .. mpm_settings.instance .. "/" .. object .. "/" .. item
local b, c, h = mpm.request(url)
local value = b:match([[val="(.-)"]])
local value = tonumber(value)
return value
-- function to post data to mpm
function post_data_to_mpm(mpm_settings,object,item,value)
local url = "http://" .. mpm_settings.username .. ":" .. mpm_settings.password .. "@" .. mpm_settings.ip .. "/obix/network/" .. mpm_settings.node .. "/DEV" .. mpm_settings.instance .. "/" .. object .. "/" .. item .. "/"
local reqBody = [[<intl val="]] .. value .. [["/>]]
local headers = {["Content-Type"] = "text/xml", ["Content-Length"] = #reqBody}
local respTable = {}
local returnList = {client = {}, code = {}, headers = {}, status = {}}
local source=ltn12.source.string(reqBody)
local sink=ltn12.sink.table(respTable)
local result = mpm.request{url=url, method="POST", source=source, sink=sink, headers=headers}
return result
Erwin van der Zwart
Threads: 39
cool !!
Thank for the info
SE ECO EXPERT
Threads: 7
(05.03.2016, 14:00) domotiqa Wrote: cool !!
Thank for the info
You will need to add this: local mpm = require('socket.http') before using the mpm.request. The request is made to a basic auhtentication server.
I have a mpm.digest libary if you need digest login.
Have fun with it (;
Erwin van der Zwart
Threads: 100
good job, Erwin!
Threads: 100
thanks to
Erwin van der Zwart , I am glad to post a complete oBIX module for integration with SmartStruxure Lite including Digest Authentication user library.
1. oBIX to MPM with digest - use as event or resident based script
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
require (
'user.mpm_functions' )
mpm_settings =
get_mpm_settings (
1 ,
true )
result =
get_data_from_mpm (
mpm_settings ,
"AV61" ,
"Present_Value" )
log (
result )
post_data_to_mpm (
mpm_settings ,
"AV61" ,
"Present_Value" ,
111 )
result =
get_data_from_mpm (
mpm_settings ,
"AV62" ,
"Present_Value" )
log (
result )
post_data_to_mpm (
mpm_settings ,
"AV62" ,
"Present_Value" ,
222 )
2. user.mpm_functions for oBIX to MPM with digest - user libary 1
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
local mpm =
require "user.mpm_digest"
function get_mpm_settings (
mpm_number ,
autoresolve )
function resolve_node ()
local url =
"http://" ..
mpm_username ..
mpm_password ..
mpm_ip
local b ,
c ,
h =
mpm.request (
url )
if h then
mpm_node_id =
string.sub (
h.server ,
1 ,
7 )
return mpm_node_id
if mpm_number ==
1 then
mpm_ip =
'192.168.10.205'
mpm_username =
'admin'
mpm_password =
'Schneider'
mpm_node_id =
'N004EAB'
mpm_instance =
100
elseif mpm_number ==
2 then
mpm_ip =
'192.168.10.206'
mpm_username =
'admin'
mpm_password =
'Schneider'
mpm_node_id =
'N005EAB'
mpm_instance =
150
3 then
mpm_ip =
'192.168.10.207'
mpm_username =
'admin'
mpm_password =
'Schneider'
mpm_node_id =
'N006EAB'
mpm_instance =
200
mpm_ip =
'10.50.80.3'
mpm_username =
'admin'
mpm_password =
'admin'
mpm_node_id =
'N000000'
autoresolve =
true
mpm_instance =
100
MPM_Settings = {
ip =
mpm_ip ,
username =
mpm_username ,
password =
mpm_password ,
node =
mpm_node_id ,
instance =
mpm_instance }
if autoresolve then
MPM_Settings.node =
resolve_node ()
return MPM_Settings
function get_data_from_mpm (
mpm_settings ,
object ,
item )
local url =
"http://" ..
mpm_settings.ip ..
"/obix/network/" ..
"/DEV" ..
object ..
item
local b ,
c ,
h =
mpm.request (
url )
local value =
b :
match (
[[val="(.-)"]] )
local value =
tonumber (
value )
return value
function post_data_to_mpm (
mpm_settings ,
object ,
item ,
value )
local url =
"http://" ..
mpm_settings.ip ..
"/obix/network/" ..
"/DEV" ..
object ..
item ..
local reqBody =
[[<intl val="]] ..
value ..
local headers = {[
"Content-Type" ] =
"text/xml" , [
"Content-Length" ] = #
reqBody }
client = {},
code = {},
headers = {},
status = {}}
local source =
ltn12.source.string (
reqBody )
local sink =
ltn12.sink.table (
respTable )
local result =
mpm.request {
url =
url ,
method =
"POST" ,
source =
source ,
sink =
sink ,
headers =
headers }
return result
3. user.mpm_digest for oBIX to MPM with digest - user libary 2
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486
local md5sum =
nil
local md5 = {}
local char ,
byte ,
format ,
rep ,
sub =
string.char ,
string.byte ,
string.format ,
string.rep ,
string.sub
local bit_or ,
bit_and ,
bit_not ,
bit_xor ,
bit_rshift ,
bit_lshift
local ok ,
bit =
pcall (
require ,
'bit' )
if ok then
bit_or ,
bit_and ,
bit_not ,
bit_xor ,
bit_rshift ,
bit_lshift =
bit.bor ,
bit.band ,
bit.bnot ,
bit.bxor ,
bit.rshift ,
bit.lshift
ok ,
bit =
pcall (
require ,
'bit32' )
if ok then
bit_not =
bit.bnot
local tobit =
function (
n )
return n <=
0x7fffffff and n or -(
bit_not (
n ) +
1 )
local normalize =
function (
f )
return function (
a ,
b )
return tobit (
f (
tobit (
a ),
tobit (
b )))
bit_or ,
bit_and ,
bit_xor =
normalize (
bit.bor ),
normalize (
bit.band ),
normalize (
bit.bxor )
bit_rshift ,
bit_lshift =
normalize (
bit.rshift ),
normalize (
bit.lshift )
local function tbl2number (
tbl )
local result =
local power =
for i =
1 , #
tbl do
result =
result +
tbl [
i ] *
power
power =
power *
return result
local function expand (
t1 ,
t2 )
local big ,
small =
t1 ,
t2
if (#
big < #
small )
then
big ,
small =
small ,
big
for i = #
small +
1 , #
big do
small [
i ] =
local to_bits
bit_not =
function (
n )
local tbl =
to_bits (
n )
local size =
math.max (#
tbl ,
32 )
for i =
1 ,
size do
if (
tbl [
i ] ==
1 )
then
tbl [
i ] =
tbl [
i ] =
return tbl2number (
tbl )
to_bits =
function (
n )
if (
n <
0 )
then
return to_bits (
bit_not (
math.abs (
n )) +
1 )
local tbl = {}
local cnt =
local last
while n >
0 do
last =
n %
tbl [
cnt ] =
last
n = (
n-last )/
cnt =
cnt +
return tbl
bit_or =
function (
m ,
n )
local tbl_m =
to_bits (
m )
local tbl_n =
to_bits (
n )
expand (
tbl_m ,
tbl_n )
local tbl = {}
for i =
1 , #
tbl_m do
if (
tbl_m [
i ]==
0 and tbl_n [
i ] ==
0 )
then
tbl [
i ] =
tbl [
i ] =
return tbl2number (
tbl )
bit_and =
function (
m ,
n )
local tbl_m =
to_bits (
m )
local tbl_n =
to_bits (
n )
expand (
tbl_m ,
tbl_n )
local tbl = {}
for i =
1 , #
tbl_m do
if (
tbl_m [
i ]==
0 or tbl_n [
i ] ==
0 )
then
tbl [
i ] =
tbl [
i ] =
return tbl2number (
tbl )
bit_xor =
function (
m ,
n )
local tbl_m =
to_bits (
m )
local tbl_n =
to_bits (
n )
expand (
tbl_m ,
tbl_n )
local tbl = {}
for i =
1 , #
tbl_m do
if (
tbl_m [
i ] ~=
tbl_n [
i ])
then
tbl [
i ] =
tbl [
i ] =
return tbl2number (
tbl )
bit_rshift =
function (
n ,
bits )
local high_bit =
if (
n <
0 )
then
n =
bit_not (
math.abs (
n )) +
high_bit =
0x80000000
local floor =
math.floor
for i =
1 ,
bits do
n =
n /
n =
bit_or (
floor (
n ),
high_bit )
return floor (
n )
bit_lshift =
function (
n ,
bits )
if (
n <
0 )
then
n =
bit_not (
math.abs (
n )) +
for i =
1 ,
bits do
n =
n *
return bit_and (
n ,
0xFFFFFFFF )
local function lei2str (
i )
local f =
function (
s )
return char (
bit_and (
bit_rshift (
i ,
s ),
255 ))
return f (
0 )..
f (
8 )..
f (
16 )..
f (
24 )
local function str2bei (
s )
local v =
for i =
1 , #
s do
v =
v *
256 +
byte (
s ,
i )
return v
local function str2lei (
s )
local v =
for i = #
s ,
1 ,-
1 do
v =
v *
256 +
byte (
s ,
i )
return v
local function cut_le_str (
s ,...)
local o ,
r =
1 , {}
local args = {...}
for i =
1 , #
args do
table.insert (
r ,
str2lei (
sub (
s ,
o ,
o +
args [
i ] -
1 )))
o =
o +
args [
i ]
return r
local swap =
function (
w )
return str2bei (
lei2str (
w ))
local function hex2binaryaux (
hexval )
return char (
tonumber (
hexval ,
16 ))
local function hex2binary (
hex )
local result ,
_ =
hex :
gsub (
hex2binaryaux )
return result
local CONSTS = {
0xd76aa478 ,
0xe8c7b756 ,
0x242070db ,
0xc1bdceee ,
0xf57c0faf ,
0x4787c62a ,
0xa8304613 ,
0xfd469501 ,
0x698098d8 ,
0x8b44f7af ,
0xffff5bb1 ,
0x895cd7be ,
0x6b901122 ,
0xfd987193 ,
0xa679438e ,
0x49b40821 ,
0xf61e2562 ,
0xc040b340 ,
0x265e5a51 ,
0xe9b6c7aa ,
0xd62f105d ,
0x02441453 ,
0xd8a1e681 ,
0xe7d3fbc8 ,
0x21e1cde6 ,
0xc33707d6 ,
0xf4d50d87 ,
0x455a14ed ,
0xa9e3e905 ,
0xfcefa3f8 ,
0x676f02d9 ,
0x8d2a4c8a ,
0xfffa3942 ,
0x8771f681 ,
0x6d9d6122 ,
0xfde5380c ,
0xa4beea44 ,
0x4bdecfa9 ,
0xf6bb4b60 ,
0xbebfbc70 ,
0x289b7ec6 ,
0xeaa127fa ,
0xd4ef3085 ,
0x04881d05 ,
0xd9d4d039 ,
0xe6db99e5 ,
0x1fa27cf8 ,
0xc4ac5665 ,
0xf4292244 ,
0x432aff97 ,
0xab9423a7 ,
0xfc93a039 ,
0x655b59c3 ,
0x8f0ccc92 ,
0xffeff47d ,
0x85845dd1 ,
0x6fa87e4f ,
0xfe2ce6e0 ,
0xa3014314 ,
0x4e0811a1 ,
0xf7537e82 ,
0xbd3af235 ,
0x2ad7d2bb ,
0xeb86d391 ,
0x67452301 ,
0xefcdab89 ,
0x98badcfe ,
0x10325476
local f =
function (
x ,
y ,
z )
return bit_or (
bit_and (
x ,
y ),
bit_and (-
x-1 ,
z ))
local g =
function (
x ,
y ,
z )
return bit_or (
bit_and (
x ,
z ),
bit_and (
y ,-
z-1 ))
local h =
function (
x ,
y ,
z )
return bit_xor (
x ,
bit_xor (
y ,
z ))
local i =
function (
x ,
y ,
z )
return bit_xor (
y ,
bit_or (
x ,-
z-1 ))
local z =
function (
f ,
a ,
b ,
c ,
d ,
x ,
s ,
ac )
a =
bit_and (
a +
f (
b ,
c ,
d )+
x +
ac ,
0xFFFFFFFF )
return bit_or (
bit_lshift (
bit_and (
a ,
bit_rshift (
0xFFFFFFFF ,
s )),
s ),
bit_rshift (
a ,
32 -
s ))+
b
local function transform (
A ,
B ,
C ,
D ,
X )
local a ,
b ,
c ,
d =
A ,
B ,
C ,
D
local t =
CONSTS
a =
z (
f ,
a ,
b ,
c ,
d ,
X [
0 ],
7 ,
t [
1 ])
d =
z (
f ,
d ,
a ,
b ,
c ,
X [
1 ],
12 ,
t [
2 ])
c =
z (
f ,
c ,
d ,
a ,
b ,
X [
2 ],
17 ,
t [
3 ])
b =
z (
f ,
b ,
c ,
d ,
a ,
X [
3 ],
22 ,
t [
4 ])
a =
z (
f ,
a ,
b ,
c ,
d ,
X [
4 ],
7 ,
t [
5 ])
d =
z (
f ,
d ,
a ,
b ,
c ,
X [
5 ],
12 ,
t [
6 ])
c =
z (
f ,
c ,
d ,
a ,
b ,
X [
6 ],
17 ,
t [
7 ])
b =
z (
f ,
b ,
c ,
d ,
a ,
X [
7 ],
22 ,
t [
8 ])
a =
z (
f ,
a ,
b ,
c ,
d ,
X [
8 ],
7 ,
t [
9 ])
d =
z (
f ,
d ,
a ,
b ,
c ,
X [
9 ],
12 ,
t [
10 ])
c =
z (
f ,
c ,
d ,
a ,
b ,
X [
10 ],
17 ,
t [
11 ])
b =
z (
f ,
b ,
c ,
d ,
a ,
X [
11 ],
22 ,
t [
12 ])
a =
z (
f ,
a ,
b ,
c ,
d ,
X [
12 ],
7 ,
t [
13 ])
d =
z (
f ,
d ,
a ,
b ,
c ,
X [
13 ],
12 ,
t [
14 ])
c =
z (
f ,
c ,
d ,
a ,
b ,
X [
14 ],
17 ,
t [
15 ])
b =
z (
f ,
b ,
c ,
d ,
a ,
X [
15 ],
22 ,
t [
16 ])
a =
z (
g ,
a ,
b ,
c ,
d ,
X [
1 ],
5 ,
t [
17 ])
d =
z (
g ,
d ,
a ,
b ,
c ,
X [
6 ],
9 ,
t [
18 ])
c =
z (
g ,
c ,
d ,
a ,
b ,
X [
11 ],
14 ,
t [
19 ])
b =
z (
g ,
b ,
c ,
d ,
a ,
X [
0 ],
20 ,
t [
20 ])
a =
z (
g ,
a ,
b ,
c ,
d ,
X [
5 ],
5 ,
t [
21 ])
d =
z (
g ,
d ,
a ,
b ,
c ,
X [
10 ],
9 ,
t [
22 ])
c =
z (
g ,
c ,
d ,
a ,
b ,
X [
15 ],
14 ,
t [
23 ])
b =
z (
g ,
b ,
c ,
d ,
a ,
X [
4 ],
20 ,
t [
24 ])
a =
z (
g ,
a ,
b ,
c ,
d ,
X [
9 ],
5 ,
t [
25 ])
d =
z (
g ,
d ,
a ,
b ,
c ,
X [
14 ],
9 ,
t [
26 ])
c =
z (
g ,
c ,
d ,
a ,
b ,
X [
3 ],
14 ,
t [
27 ])
b =
z (
g ,
b ,
c ,
d ,
a ,
X [
8 ],
20 ,
t [
28 ])
a =
z (
g ,
a ,
b ,
c ,
d ,
X [
13 ],
5 ,
t [
29 ])
d =
z (
g ,
d ,
a ,
b ,
c ,
X [
2 ],
9 ,
t [
30 ])
c =
z (
g ,
c ,
d ,
a ,
b ,
X [
7 ],
14 ,
t [
31 ])
b =
z (
g ,
b ,
c ,
d ,
a ,
X [
12 ],
20 ,
t [
32 ])
a =
z (
h ,
a ,
b ,
c ,
d ,
X [
5 ],
4 ,
t [
33 ])
d =
z (
h ,
d ,
a ,
b ,
c ,
X [
8 ],
11 ,
t [
34 ])
c =
z (
h ,
c ,
d ,
a ,
b ,
X [
11 ],
16 ,
t [
35 ])
b =
z (
h ,
b ,
c ,
d ,
a ,
X [
14 ],
23 ,
t [
36 ])
a =
z (
h ,
a ,
b ,
c ,
d ,
X [
1 ],
4 ,
t [
37 ])
d =
z (
h ,
d ,
a ,
b ,
c ,
X [
4 ],
11 ,
t [
38 ])
c =
z (
h ,
c ,
d ,
a ,
b ,
X [
7 ],
16 ,
t [
39 ])
b =
z (
h ,
b ,
c ,
d ,
a ,
X [
10 ],
23 ,
t [
40 ])
a =
z (
h ,
a ,
b ,
c ,
d ,
X [
13 ],
4 ,
t [
41 ])
d =
z (
h ,
d ,
a ,
b ,
c ,
X [
0 ],
11 ,
t [
42 ])
c =
z (
h ,
c ,
d ,
a ,
b ,
X [
3 ],
16 ,
t [
43 ])
b =
z (
h ,
b ,
c ,
d ,
a ,
X [
6 ],
23 ,
t [
44 ])
a =
z (
h ,
a ,
b ,
c ,
d ,
X [
9 ],
4 ,
t [
45 ])
d =
z (
h ,
d ,
a ,
b ,
c ,
X [
12 ],
11 ,
t [
46 ])
c =
z (
h ,
c ,
d ,
a ,
b ,
X [
15 ],
16 ,
t [
47 ])
b =
z (
h ,
b ,
c ,
d ,
a ,
X [
2 ],
23 ,
t [
48 ])
a =
z (
i ,
a ,
b ,
c ,
d ,
X [
0 ],
6 ,
t [
49 ])
d =
z (
i ,
d ,
a ,
b ,
c ,
X [
7 ],
10 ,
t [
50 ])
c =
z (
i ,
c ,
d ,
a ,
b ,
X [
14 ],
15 ,
t [
51 ])
b =
z (
i ,
b ,
c ,
d ,
a ,
X [
5 ],
21 ,
t [
52 ])
a =
z (
i ,
a ,
b ,
c ,
d ,
X [
12 ],
6 ,
t [
53 ])
d =
z (
i ,
d ,
a ,
b ,
c ,
X [
3 ],
10 ,
t [
54 ])
c =
z (
i ,
c ,
d ,
a ,
b ,
X [
10 ],
15 ,
t [
55 ])
b =
z (
i ,
b ,
c ,
d ,
a ,
X [
1 ],
21 ,
t [
56 ])
a =
z (
i ,
a ,
b ,
c ,
d ,
X [
8 ],
6 ,
t [
57 ])
d =
z (
i ,
d ,
a ,
b ,
c ,
X [
15 ],
10 ,
t [
58 ])
c =
z (
i ,
c ,
d ,
a ,
b ,
X [
6 ],
15 ,
t [
59 ])
b =
z (
i ,
b ,
c ,
d ,
a ,
X [
13 ],
21 ,
t [
60 ])
a =
z (
i ,
a ,
b ,
c ,
d ,
X [
4 ],
6 ,
t [
61 ])
d =
z (
i ,
d ,
a ,
b ,
c ,
X [
11 ],
10 ,
t [
62 ])
c =
z (
i ,
c ,
d ,
a ,
b ,
X [
2 ],
15 ,
t [
63 ])
b =
z (
i ,
b ,
c ,
d ,
a ,
X [
9 ],
21 ,
t [
64 ])
return A +
a ,
B +
b ,
C +
c ,
D +
d
function md5.sumhexa (
s )
local msgLen = #
s
local padLen =
56 -
msgLen %
64
if msgLen %
64 >
56 then padLen =
padLen +
64 end
if padLen ==
0 then padLen =
64 end
s =
s ..
char (
128 ) ..
rep (
char (
0 ),
padLen-1 ) ..
lei2str (
8 *
msgLen ) ..
lei2str (
0 )
assert (#
s %
64 ==
0 )
local t =
CONSTS
local a ,
b ,
c ,
d =
t [
65 ],
t [
66 ],
t [
67 ],
t [
68 ]
for i =
1 ,#
s ,
64 do
local X =
cut_le_str (
sub (
s ,
i ,
i +
63 ),
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 ,
4 )
assert (#
X ==
16 )
X [
0 ] =
table.remove (
X ,
1 )
a ,
b ,
c ,
d =
transform (
a ,
b ,
c ,
d ,
X )
return format (
"%08x%08x%08x%08x" ,
swap (
a ),
swap (
b ),
swap (
c ),
swap (
d ))
function md5.sum (
s )
return hex2binary (
md5.sumhexa (
s ))
do
local ok ,
mod =
pcall (
require ,
"crypto" )
if ok then
local digest = (
mod.evp or mod ).
digest
if digest then
md5sum =
function (
str )
return digest (
"md5" ,
str )
if not md5sum then
local md5 = (
type (
mod ) ==
"table" )
and mod or md5
md5sum =
md5.sumhexa or md5.digest
if not md5sum then
ok =
pcall (
require ,
"digest" )
if ok and md5 then md5sum =
md5.digest end
local s_http =
require "socket.http"
local s_url =
require "socket.url"
local ltn12 =
require "ltn12"
local hash =
function (...)
return md5sum (
table.concat ({...},
local parse_header =
function (
h )
local r = {}
for k ,
v in (
h ..
gmatch (
"(%w+)=(.-)," )
do
if v :
sub (
1 ,
1 ) ==
'"' then
r [
k :
lower ()] =
v :
sub (
2 , -
2 )
else r [
k :
lower ()] =
v end
return r
local make_digest_header =
function (
t )
local s = {}
local x
for i =
1 ,#
t do
x =
t [
i ]
if x.unquote then
s [
i ] =
x [
1 ] ..
x [
2 ]
s [
i ] =
x [
1 ] ..
x [
2 ] ..
return "Digest " ..
table.concat (
s ,
local hcopy =
function (
t )
local r = {}
for k ,
v in pairs (
t )
do r [
k ] =
v end
return r
local _request =
function (
t )
if not t.url then error (
"missing URL" )
local url =
s_url.parse (
t.url )
local user ,
password =
url.user ,
url.password
if not (
user and password )
then
error (
"missing credentials in URL" )
url.user ,
url.password ,
url.authority ,
url.userinfo =
nil ,
nil ,
nil ,
nil
t.url =
s_url.build (
url )
local ghost_source
if t.source then
local ghost_chunks = {}
local ghost_capture =
function (
x )
if x then ghost_chunks [#
ghost_chunks +
1 ] =
x end
return x
local ghost_i =
ghost_source =
function ()
ghost_i =
ghost_i +
return ghost_chunks [
ghost_i ]
t.source =
ltn12.source.chain (
t.source ,
ghost_capture )
local b ,
c ,
h =
s_http.request (
t )
if (
c ==
401 )
and h [
"www-authenticate" ]
then
local ht =
parse_header (
h [
"www-authenticate" ])
assert (
ht.realm and ht.nonce and ht.opaque )
if ht.qop ~=
"auth" then
return nil ,
string.format (
"unsupported qop (%s)" ,
tostring (
ht.qop ))
if ht.algorithm and (
ht.algorithm :
lower () ~=
"md5" )
then
return nil ,
string.format (
"unsupported algo (%s)" ,
tostring (
ht.algorithm ))
local nc ,
cnonce =
"00000001" ,
string.format (
"%08x" ,
os.time ())
local uri =
s_url.build {
path =
url.path ,
query =
url.query }
local method =
t.method or "GET"
local response =
hash (
hash (
user ,
ht.realm ,
password ),
ht.nonce ,
nc ,
cnonce ,
"auth" ,
hash (
method ,
uri )
t.headers =
t.headers or {}
t.headers.authorization =
make_digest_header {
"username" ,
user },
"realm" ,
ht.realm },
"nonce" ,
ht.nonce },
"uri" ,
uri },
"cnonce" ,
cnonce },
"nc" ,
nc ,
unquote =
true },
"qop" ,
"auth" },
"algorithm" ,
"MD5" },
"response" ,
response },
"opaque" ,
ht.opaque },
if not t.headers.cookie and h [
"set-cookie" ]
then
local cookie = (
h [
"set-cookie" ] ..
match (
if cookie then
t.headers.cookie =
"$Version: 0; " ..
cookie ..
if t.source then t.source =
ghost_source end
b ,
c ,
h =
s_http.request (
t )
return b ,
c ,
h
else return b ,
c ,
h end
local request =
function (
x )
local _t =
type (
x )
if _t ==
"table" then
return _request (
hcopy (
x ))
elseif _t ==
"string" then
local r = {}
local _ ,
c ,
h =
_request {
url =
x ,
sink =
ltn12.sink.table (
r )}
return table.concat (
r ),
c ,
h
else error (
string.format (
"unexpected type %s" ,
_t ))
return {
request =
request ,
