modbus variable with 4 memory locations
hi.
I currently have a meter that has a modbus variable with 4 memory locations, someone knows how I can convert that variable to 32 bit format or higher
-- init modbus on first script execution
if not mb then
    require('luamodbus')
    mb = luamodbus.rtu()
    mb:open('/dev/ttyS2', 9600, 'E', 8, 1, 'H')
    mb:connect()
-- sets slave ID to read/write data from/to
mb:setslave(20)
-- read 3-phase system voltage from 32-bit register
r1, r2 = mb:readregisters(0x1000, 2)
result = bit.lshift(r1, 16) + r2
grp.write('5/5/1',result)
-- read 3-phase system current from 32-bit register
r1, r2 = mb:readregisters(0x100E, 2)
grp.write('5/5/2',result)
I was looking at this example, but I can not find out how I can do it
thank you
For ModBus the recommended approach is to use mapper with profiles. It supports all kind of numeric values up to 64 bits.
Well, I'm new to this, you can explain to me how I could do that or if there is an example that I can take as a reference.
Check this thread: https://forum.logicmachine.net/showthread.php?tid=839
