spaceLYnk Hw Version?
#21
Ah, ok, thank you. It is a 3 then.
Is there a way to get this info with a script, in addition to FW version and CPU load?
Try this:
local ARM = io.readproc('cat /proc/cpuinfo | grep \"model name\"'):match('%d+') log(ARM) local FW = io.readfile('/lib/genohm-scada/version'):split('.') FW = FW[1]*1000000 + FW[2]*1000 + FW[3] log(FW)
(10.03.2019, 00:07)Erwin van der Zwart Wrote: Hi,
Try this:
Great, thats what I need. Thank you!
Hi Erwin,
is possible to use your script with latest LM? I just tried to start it, and receive back this:
FW * string: 7
and error log:
Resident script:6: attempt to perform arithmetic on a nil value
stack traceback:
Yes should work but i think i try to multiply a string value in line 6.
Change FW[1] to tonumber(FW[1]) and do the same with 2 and 3.
Or remove line 6 to get the FW as RAW string, we needed it to BACnet
and the controller does not support BACnet string values so that is why
we convert it to a analog value like 2003001. In this case it’s FW 2.3.1
LM version is already a number in YYYYMMDD format, so split is not needed.
In that case you can use:
log(FW)
thank you for answers, FW now shoved correctly, but this code below no any log at all.. May be it depends of CPU type?
log(ARM)
cpu = io.readfile('/proc/cpuinfo'):match('model name%s+:%s+([^%s]+)') log(cpu)
If i read this correctly is the spacelynk hw3 better on ram and cpu than the lm5 power? Looks like lm5 power only have 528 mhz cpu and 128 mb ram?
http://openrb.com/imx28-vs-imx6-cpu-test...icmachine/
Latest LMs have 900MHz CPU and 256MB RAM.
(26.06.2019, 06:50)admin Wrote: Latest LMs have 900MHz CPU and 256MB RAM.
Ok. So this is the same as SL. Is the trending capacity better than 21 mb on one of them? LM\SL?
No it is the same. The limit is due to size of SPI flash.
the HW v.3 .1 of spacelynk doesn't integrate the remote without P.F anymore ?
spaceLYnk never has supported the remote app (Wiser for KNX) independent of HW version.
If you want to use Wiser for KNX remote app you need a Wiser for KNX hardware.
