After upgrading to the latest stable firmware, all of the KNX to bacnet mappings was deleted from my logic machine. Before i did the upgrade, i downloaded a backup-file.
After the upgrade, i get "Backup file invalid" when trying to restore.
If I download a new backup and then use restore, it goes well.
(24.04.2019, 10:49)admin Wrote: Since there's a db directory there this is a newer backup. Are you trying to use an older firmware?
No i didnt think so, but then again i forgot to check the old version before i ran the upgrade. I didnt think it was possible to "upgrade" to a lower version?
Now I have the 2017.6.20
(24.04.2019, 10:59)Daniel. Wrote: This backup works fine on RC1 so was probably created in this FW. It will not run on older firmware. Just upgrade to RC1 and it will work.
Can you please link to the correct Firmware so i dont mess this up again?
