LM4 replace by LM5P2-KC
I have a LM4 and need more cpu power and i like CAN bus. What i use now:
- KNX
- Zwave (ZMEEUZB USB stick)
- 1Wire
Is it possible to replace them by a LM5P2-KC so i also have a CAN connection for the future?
- KNX is onboard
- Zwave (can i insert my usb stick and restore the backup or do i need more?)
- 1Wire (adding a usb DS9490R)
Or is there a better one?
- CPU,MEM max
- KNX
- CAN
- Zwave on USB
- 1Wire (on USB?)
You can buy any other LM with CANx and use LM4 just as interface. They will still talk over KNX IP.
KNX+CAN model has only 1 USB port
(09.10.2019, 13:33)admin Wrote: KNX+CAN model has only 1 USB port
I can use an usb hub
(09.10.2019, 13:21)Daniel. Wrote: You can buy any other LM with CANx and use LM4 just as interface. They will still talk over KNX IP.
i only use it for logic, no visu.
