Hi Pawel,
Can you describe the issue in more detail, as i don't understand what "I can't add some devices to have unlimited access do visualization" has to do with the user access.
I assume you mean clients like iPad's and Touchpanels etc.
In the new firmware the links are the same with #pagenumber but the URL is slightly changed now you need to use
http://admin:admin@192.168.0.10/scada-vis/#1
You can also see those direct url's when you open the preview from the editor (select a page and click the button located on left bottom and use the middle icon to open preview)
The direct URL is showed in the header of the preview page.
The user access and saving of the password is just like in 1.3.1 only we added some extra settings to set your startup page so you can skip the original (green) startup page.
To open the visu without using the password you can send it as basic authentication in your shortcut url like: http://
You can now set (under user access -> default user access settings) the default page to 'pc/tablet visu' and create a logout button under plan editor tab 'link' to logout function.
Did you also cleaned your browser cache after FW update?
Erwin van der Zwart
