Flie size converting ets file
Having some issues when trying to convert using your tool at https://openrb.com/knxproj/
Are there some limitations on the size of the file?
How big is the knxproj file?
(09.12.2019, 09:02)admin Wrote: How big is the knxproj file?
Filesize is about 65 mb..
Try now, see if it works.
What is this tool for? You can import your ets project directly in LM with OPC export option, isn't it?
You will get correct data types (ESF only provides data size in bytes but not correct type) and you can include parent level names in object names.
(09.12.2019, 13:07)admin Wrote: You will get correct data types (ESF only provides data size in bytes but not correct type) and you can include parent level names in object names.
Cool! Thank you.
Works great now. Thanks for help..
