W4K LOUVER SMARTPHONE VISU
Hello guys!
Is there any way to have only one louver widget to do the following actions: UP/STOP/DOWN?
Now I have two widgets for one louver as you can see in the picture. The issue is that in the living room i have six louvers, that means twelve objects. Any help would be appreciated!
Does your device support 4-bit telegrams? There's a built-in control for 4-bit that sends up/down when button pressed and stop when button is released.
Or use the position object with a slider, then you can set it to any level desired...
Dear admin my device MTN649804 doesnt support 4-bit telegram.
Dear Erwin the louvers are ON/OFF they do not have possition.
For now i use one object for up/down and one object for stop.
Yes, lack of this feature is annoying. I solved it with two sliders as a general controller for all blinds together. Plus 6 sliders as a widget.
