Push notifications Android/iOS tutorial
Hi.
Is there a way for make this work on Wiser for Knx?
(06.01.2020, 18:55)victor.back Wrote: Hi.
Whatever is linked with cloud SE do not want to use it. We can't help.
You could use this: https://openrb.com/send-instant-messages-to-ios-and-android-devices-with-lm/
B
R,
(07.01.2020, 15:29)Erwin van der Zwart Wrote: Hi,
B
R,
What about SIRI?
I want to control lights from Siri...
Regards
GIA
Best Regards
NewBee to wiser
We are currently testing Alexa and Google Assistant, this will be included in the upcoming release of Touch 3, the team is also investigating the option to have homeKit support but is not confirmed that it will be added yet.
Hi, ok.
In my case I want SIRI to open garage door when driving.
I dont think alexa or Google will solve that?
LM seems to have a feature/app for Siri and voice control.
Is it possible to change Wiser to LM software?
Sent from my iPhone using Tapatalk
Best Regards
NewBee to wiser
You could use Siri shortcuts combined with remote services..
Are u sure?When I try, iPhone Shortcuts can’t find Wiser !
Best Regards
NewBee to wiser
Yes i’m sure, you need to use a URL trigger to the remote services of the controller
I found out what you mean by URL in shortcuts.
But Wiser for KNX remote app, will not show any URL.
Can you record a «how to do it»?
Regards
GIA
Best Regards
NewBee to wiser
It's available a user manual of Iphone app for "logic machine"?
It's necessary register for use logic machine cloud?
Best regards
Fabio Rusconi
If you want to use push notifications then yes you must have an account and login in the cloud app. The workflow is same for iOS and Android. See the video above. The app has slightly different look and feel.
(28.10.2020, 11:38)Daniel. Wrote: If you want to use push notifications then yes you must have an account and login in the cloud app. The workflow is same for iOS and Android. See the video above. The app has slightly different look and feel.
I need set the app. I don't understad how i can set the acces parameter (It ask me a email and a password for cloud.logica.machine.net).
Go here https://cloud.logicmachine.net/user-mana...auth/login
Register, accept the email is sent to you and then use the credential in the cloud app.
(28.10.2020, 11:56)Daniel. Wrote: Go here https://cloud.logicmachine.net/user-mana...auth/login
Thank you.
Fabio
(29.11.2017, 13:41)edgars Wrote:
Hi Edgars
The push notification is really useful, I noticed that if it disappears there is no history to consult, it would be possible in the mobile device app to have the notification streak.
Thank you
You can use telegram bot integration if you want notification history.
(09.02.2021, 16:29)admin Wrote: You can use telegram bot integration if you want notification history.
Hello Admin
Could you share an example?
regards,
Best Regards,
See this: https://forum.logicmachine.net/showthrea...1#pid17111
