Direct input/Step +/-
I'm new to the forum and a new user of the logic machine, so forgive me if I have a stupid question.   Blush
I try to make a visualization to control te heating of my home. For the adjustement of the temperature, I want to use a 'Direct input/Step +/-'. I have to questions: about the use of it:
  • Can I adjust the size of the object. It is quiet large in comparison of the rest of the visualization..
  • Can I change the step so I can change the temperature with 0,5°?
Thank in advance,
Amelie
1. You can do it via custom css like this. Change will be visible only in Visu not editor
.item-control-single .control-spinner {
  transform: scale(0.75);
  transform-origin: 0 0;
2. In object visualisation parameters there is step you can set.
(12.02.2020, 11:02)Daniel. Wrote: Hi
Thank you for the CSS-tip. It worked!
But, when I look at the visualization parameters, I can only change the steps with an integer. What, Am I doing wrong? The object type is a 2-byte
floating point, so I don't think this is causing the problem.
2 byte float?
