RFID reader integration over RS-232
The example below shows how to integrate Idesco Access 7 C RFID reader over RS-232 port. The script below will read all RFID cards and log IDs. The script is easy adjustable if there is a necessity to trigger specific KNX, Bacnet etc. objects.
Add the following resident script with sleep-time = 0:
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748
-- init if not port then  require('serial')  port = serial.open('/dev/RS232', { baudrate = 9600 })  function readid(port)    local char, byte, line, id, csum, val    -- wait for start byte    char = port:read(1, 1)    if not char then      return nil, 'timeout'    end    -- start byte must be STX    byte = char:byte(1)    if byte ~= 2 then      return nil, 'wrong start byte'    end    -- read remaining line    line = port:read(15, 1)    if not line then      return nil, 'failed to read data'    end    -- calculate checksum    csum = 0    for i = 1, 11 do      val = tonumber(line:sub(i, i), 16)      csum = bit.bxor(csum, val)    end    -- verify checksum    if csum ~= tonumber(line:sub(12, 12), 16) then      return nil, 'invalid checksum'    end    -- return ID    return line:sub(1, 10)  end end id = readid(port) if id then  log(id) end
Would this also work with the latest Idesco’s 8 CD 2.0 MI readers?
That's a question for the manufacturer not us Smile You should contact their support.
Well, obviously I put my question wrongly:
As it might be a matter of opinion, whether this would be is a question for Idesco support or for this forum. Big Grin
From the point of view of a system integrator, the question arises in particular whether the latest 8 CD 2.0 MI readers from Idesco have already been successfully implemented with LM5 or not. Cool
Anyway, I followed your advice and emailed "their support".
If the protocol is the same then it will work
