Write to bus - if checked it send telegram to KNX bus and updates local DB, if not, updates only local DB. We will double check if this works correctly in latest version.
Polling - not all Zwave parameters supports this. OpenZwave doesn't answer to a questions which does and which doesn't.
Correction: disabling "write to bus" blocks only writes to KNX/TP but it still sends telegrams over IP. If you are monitoring KNX bus via LM, you will still see all telegrams.
(30.06.2016, 09:58)admin Wrote: Correction: disabling "write to bus" blocks only writes to KNX/TP but it still sends telegrams over IP. If you are monitoring KNX bus via LM, you will still see all telegrams.
I monitor the telegrams with another ip device, but i see the messages and i have disabled "write to bus"
