Threads: 94
I tried to find out other post in forum without success.
A customer of mine would like to use home plant as background.
I have created my own widget on which I use as background a svg file of home plant. I would like:
- to center the image in the widget.
- reduce the dimensions of the icon (light bulbs and other object).
How can I do that?
Threads: 28
As a background you could use image and position it as you want. Only make sure it is first element on the widget.
Threads: 28
Why don't you just add the image as custom?
Threads: 94
Hi Daniel,
what do you mean exactly? I did a custom widget on which I use image element.
Is there a different way? Thanks.
Threads: 28
When selecting image you can use URL or select pre-defined icons. Additionally you can upload your own custom image.
Threads: 28
Obviously this is wrong
Mosaic has nothing to do with the LM internal part, it is stand alone app.
Threads: 94
Stupid me!! Sorry Daniel.
I thought it was the just the icon. I did not test it. Sorry to bother you for this stupid question.
