How to configure the "RTU2" port for RS485
Hi,  Smile need your advice.
How to configure RTU2 port for RS485 (for Modbus RTU, half-duplex)?
I'm using LM5 Lite.
I've comfigured RTU1 port - all working fine:
RTU (serial) enabled: Yes
Port: "/dev/RS485-1
And my settings for RTU2 (that is not working Huh ) :
Port: "/dev/RS485-2" (this field was empty and i pasted  "/dev/RS485-2" manually)
/dev/RS485-2 is correct. Make sure that you don't have any other script/plugin using this port. Keep in mind that RS232 is shared with RS485-2 so it cannot be used simultaneously.
(30.04.2020, 04:20)admin Wrote: /dev/RS485-2 is correct. Make sure that you don't have any other script/plugin using this port. Keep in mind that RS232 is shared with RS485-2 so it cannot be used simultaneously.
Thank you, working!
Oh Undecided , I noticed that if you enabling RTU2 for Modbus over RS485 my TCP/IP devices (also modbus) lost communication. Do you have any idea why this is happening?
My configuration:
TCP/IP: 2 devices (Modbus TCP/IP, port 502)
RTU1:    8 devices (Modbus RTU, 9600bps)
RTU2:    1 device   (Modbus RTU, 115200bps)
PS: TCP/IP + RTU1 working fine.
What happen if you reboot LM?
(01.05.2020, 09:30)Daniel. Wrote: What happen if you reboot LM?
I haven't tried it. I 've just taken logic off.  When I get to the apartment - I'll try Smile .
After reboot LM all communications are working correctly. Thank you!
