02.05.2020, 13:49
Hi everybody,
I need to make a change on the widget security in Mosaic (see in the attached file for understand) If it is possible.
At the moment it works great but in this way:
Active makes the GA at ON and this in ON untill a Remove cmd.
I need this behavior:
when I press active, It must generate a pulse with ON value on a first GA. While when I press Remove, It must to generate another ON pulse on a different GA.
If it is not possible, is there an object on Mosaic with a password?
I hope to be clear and good weekend to all.
Best regards Cristian
