Mosaic cloud: widget view problem
I did my own widget in Mosaic, setting the background in "default widget style".
I choose CUSTOM as "preset themes" and as preset background I use one of the list (grey texture style as shown in picture).
Locally work fine without problem. Unfortunately when I connect using cloud, background of widget is not the "PRESET" (texture style) but is "Background color" (white).
Only in cloud!! It happens with IOS phone and honestly I did not test with Android phone.
How can solve it please?
I just tried the same and it worked for me.
Try here https://cloud.logicmachine.net/
It could be cache in your iphone.
(17.07.2020, 10:56)Daniel. Wrote: Hi
Hi, I tried with Android but same problem.
See enclosed.
Does this work locally for you? Which background is it?
(20.07.2020, 09:02)Daniel. Wrote: Does this work locally for you? Which background is it?
Hi Daniel,
files enclosed can help you? Yes, I confirm that locally works fine.
Send me your backup to PM, use wetransfer.com or similar. I can't recreate this.
(20.07.2020, 09:33)Daniel. Wrote: Send me your backup to PM, use wetransfer.com or similar. I can't recreate this.
Sent you by mail. Thanks.
Nothing arrived.
(20.07.2020, 10:25)Daniel. Wrote: Nothing arrived.
Sent by private message too.
Wetransfer link.
OK I see it now, We will fix it. As a work around you can specify background individually for each widget. This works.
Thank you Daniel!! Done
