Wiser for KNX virtual object problem
we are experiencing something strange with this device: one virtual object (32/1/24 but I don't think that is really relevant) kept triggering on (it is a 1 bit object) by itself after a while but it's not linked to anything in particular, no Scenes, no scheduler, no scripts and even no KNX/TP bus (we already tried to phisically disconnect it).
After we factory reset the device and reupload the configuration the problem is gone, anybody experienced that kind of behaviour?
Is there a procedure to avoid factory reset?
Thank you
Set log to it and tell us what the log says. There must be a reason why you have it.
I would like to, but it's impossible to reproduce the problem right now, we tried to analyze everything before factory reset but we didn't find anything.
I know it has to be a reason for that, I just wanted to know if anybody has experienced that kind of problem.
Since it seemed to work as a pattern (about 1 minute) we tried to see if there was a scheduled process or something similar (strange since it was a brand new device, so it was a fresh programming) but, obviously, nothing.
Daniel is right here, the only way to find out who is sending is to enable logging. Then in Object logs tab you will see local(sender) in the source address column. Possible values for the sender field:
bus = knx bus (ip or tp) bt = bluetooth bn = bacnet mb = modbus en = enocean wl = lm wall rc = reactor ek = ekey w1 = 1-wire sc = scenes se = event script ss = scheduled script sr = resident script us = user interface / visualization rm = remote services ap = apps po = group monitor object polling dl = dali
I can't do it now, if the problem comes back I will surely do.
I can only tell that when we checked (from ETS bus diagnostic) it says that wiser itself sent the message on bus, but after factory reset and reupload of the same configuration the problem is gone.
Thank you anyway.
