30.11.2020, 10:38
		Hi, I have noticed that the LM override the domain with .local, is there any reason for doing it? Is there a way to disable it?
		30.11.2020, 10:38
		30.11.2020, 10:54
		Do you mean for mDNS? What do you want to achieve with this?
		30.11.2020, 11:53
		Yes for mDNS
		03.12.2020, 10:00
		03.12.2020, 10:01
		Not at the moment. Can you describe a use case?
	 (03.12.2020, 10:01)admin Wrote: Not at the moment. Can you describe a use case? If LM takes the domain of the network: 1) it can be accessed more easily by clients, because the majority have more problems remembering the IP, instead of a name 2) it solves a lot of problems, especially when the network is not very customizable (for example the problem that I asked a few days ago with the email that was tagged SPAM because of the domain)
		04.12.2020, 10:04
		1. mDNS does not work in Android. If you have your own DNS server you can create a sub-domain that points to LM IP. 2. SMTP library does not use system hostname/domain when sending. Domain parameter must be added to the mail settings manually or default "localhost" will be used. |
