08.12.2020, 20:21
		I keep seeing requests from LG to KNX for a datapoint every 1 second. I removed all scripts with this datapoint but this doesn't fix the solution. Anyone a clue where to look for this problem?
![[Image: image.png]](https://i.ibb.co/ygy4Jdt/image.png)
					requests on KNX
		08.12.2020, 20:21
		I keep seeing requests from LG to KNX for a datapoint every 1 second. I removed all scripts with this datapoint but this doesn't fix the solution. Anyone a clue where to look for this problem? ![[Image: image.png]](https://i.ibb.co/ygy4Jdt/image.png)
		09.12.2020, 07:06
		Check object's "poll interval" setting. Most probably you have set it to 1 so a read telegram is sent each second.
		09.12.2020, 07:24
		Tnx Found it! Solved!
