requests on KNX
I keep seeing requests from LG to KNX for a datapoint every 1 second. I removed all scripts with this datapoint but this doesn't fix the solution. Anyone a clue where to look for this problem?
[Image: image.png]
Check object's "poll interval" setting. Most probably you have set it to 1 so a read telegram is sent each second.
Tnx Found it! Solved!
