21.12.2020, 21:24
I'm new to KNX, just received 2 multi-sensors and in a process to configuring them.
I'm having a weird issue here.
So, I have these 2 sensors hooked up to LM (power dr). I also have an ABB power supply in the bus.
The LM KNX mode is set to TP-UART, address 15.15.255
In the ETS I have 2 connections.
I select the "15.15.255 LogicMachine", put one of the sensors into Programming mode check the devices in the programming mode.
I get the address "15.15.255". The same with the other sensor.
It can't be right and it seems to be just the LM address all the time.
Is these some other way to figure out the addresses of the sensors?
P.S. I just tried knxlib.ping within a loop of 1.1.1-255 and found one, don't know which one. And it took a couple minutes. Probably even going through 1.*.* is not an option timewise?
