I am searching such device which can monitor radio waves on defined frequency e.g. 433,92 MHz. I want check what was sent and I want prepare the same on some transmitter which is connected to LM via some medium e.g. RS485.
The inspiration of this search was the restrictions of RS485 -> Somfy RTS transmitter in comparison to the pilots which are a lot of faster than this special transmitter. The minimum pause between 2 radio commands "down" is 0,7s. This is not the best especially when I will try send few telegrams in a short time e.g. scene or change slat angle via "step" command. End also there is the channel limitation but this is not a problem. The most important problem is very big different speed of the transmitter(very slow) and the pilots(very fast).
Maybe do you have some suggestion?
Of course I can buy some pilots and connect to their buttons via some switch actuator but maybe there is some other way...
