03.01.2021, 20:39
Your support is needed to figure out why Z-Wave app is not loading properly on a LM5p2-RDE equipped with a Z-wave.me USB stick. Below you can find the Z-wave related running processes and system log.
Running processes:
1127 lua /lib/apps/daemon.lua zwaveapp-imx6 /home/apps/store/daemon/zwaveapp-imx6/daemon.lua
1129 lua /lib/apps/daemon.lua canx /home/apps/store/daemon/canx/daemon.lua
1169 /home/apps/usr/sbin/zwave /home/apps/usr/share/openzwave/ /tmp/log/ /dev/ttyACM0 /home/apps/usr/share/zwave/handler.lua
1170 /home/apps/usr/sbin/zwave /home/apps/usr/share/openzwave/ /tmp/log/ /dev/ttyACM0 /home/apps/usr/share/zwave/handler.lua
System Log:
Jan 3 15:47:17 LogicMachine kern.notice kernel: [ 16.067592] random: nonblocking pool is initialized
Jan 3 15:47:09 LogicMachine kern.info kernel: [ 8.496104] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Jan 3 15:47:04 LogicMachine user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK
Jan 3 15:47:03 LogicMachine kern.info kernel: [ 2.607026] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Jan 3 15:47:03 LogicMachine user.info sysinit: /dev/mmcblk0p3: clean, 2648/468640 files, 77576/1873920 blocks
Jan 3 15:47:03 LogicMachine user.info sysinit: Setting free blocks count to 1796344 (was 0)
Jan 3 15:47:03 LogicMachine user.info sysinit: Setting free inodes count to 465992 (was 0)
Jan 3 15:47:03 LogicMachine user.info sysinit: /dev/mmcblk0p3: recovering journal
Jan 3 15:47:03 LogicMachine user.info sysinit: e2fsck 1.45.6 (20-Mar-2020)
Jan 3 15:47:03 LogicMachine kern.info kernel: [ 2.434352] fec 2188000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=-1)
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 1.373203] fec 2188000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=-1)
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.959349] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.735614] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.734092] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.734067] usb 1-1: New USB device found, idVendor=0658, idProduct=0200
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.595755] usb 1-1: new full-speed USB device number 2 using ci_hdrc
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.549573] Freeing unused kernel memory: 164K
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.549316] VFS: Mounted root (ext3 filesystem) on device 179:2.
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.549242] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.548080] EXT4-fs (mmcblk0p2): recovery complete
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.418431] mmcblk0: p1 p2 p3
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.416940] mmcblk0: mmc0:aaaa WD08G 7.40 GiB
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.416186] mmc0: new high speed SDHC card at address aaaa
Jan 3 15:47:02 LogicMachine kern.warn kernel: [ 0.408885] mmc0: host does not support reading read-only switch, assuming write-enable
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.391901] Waiting for root device /dev/mmcblk0p2...
Jan 3 15:47:02 LogicMachine kern.err kernel: [ 0.391836] Warning: unable to open an initial console.
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.391438] vdd3p0: disabling
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.390859] rtc-pcf85263a 0-0051: setting system clock to 2021-01-03 15:47:01 UTC (1609688821)
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.385490] can: raw protocol (rev 20120528)
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.385469] NET: Registered protocol family 29
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.385305] can: controller area network core (rev 20120528 abi 9)
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.385266] NET: Registered protocol family 17
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.385146] ip_tables: © 2000-2006 Netfilter Core Team
Jan 3 15:47:02 LogicMachine kern.warn kernel: [ 0.366345] 2198000.adc supply vref not found, using dummy regulator
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.351796] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.314256] sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.314214] sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.311335] sdhci-pltfm: SDHCI platform and OF driver helper
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.311320] sdhci: Copyright© Pierre Ossman
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.311293] sdhci: Secure Digital Host Controller Interface driver
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.310296] usbcore: registered new interface driver btusb
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.309486] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.308312] lirc_dev: IR Remote Control driver registered, major 249
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.307403] i2c /dev entries driver
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.307143] rtc-pcf85263a 0-0051: rtc core: registered rtc-pcf85263a as rtc0
Jan 3 15:47:02 LogicMachine kern.warn kernel: [ 0.303543] rtc-ds1307: probe of 0-006f failed with error -5
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.301666] hub 2-0:1.0: 1 port detected
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.301544] hub 2-0:1.0: USB hub found
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.300206] usb usb2: SerialNumber: ci_hdrc.1
Jan 3 15:47:02 LogicMachine kern.info kernel: [ 0.300184] usb usb2: Manufacturer: Linux 4.4.231 ehci_hcd
Thanks for your support
Running processes:
System Log:
