25.01.2021, 11:46
is the 'DS2423 4kbit 1-Wire RAM with Counter, device supported.
Regards Johan
Regards Johan
					1-wire DS2423
		25.01.2021, 11:46
		Hi, is the 'DS2423 4kbit 1-Wire RAM with Counter, device supported. Regards Johan
		25.01.2021, 12:00
		It is supported, but you will have to use scripts to read/write data from/to it.
		25.01.2021, 12:58
		Thanks, do you have an example to get me started. Regards Johan
		25.01.2021, 13:14
		First you need to find the unique ID of the 1-Wire device. It is shown in the UI or you can use a script to log all connected devices: Code: require('ow')Read counter values (change id value to your device ID): Code: require('ow') |
