11.02.2021, 09:14
I would like to know if it is possible to have a simple way to put data (like 11/02/2021) and time (like 08:40) into visualization, without using virtual object and script. Or if it is a way to prevent those object from being written into SD.
Now I use a resident script that run every 30 sec that read time and data and write it into an object. This means that LM write a lot of data into the SD and I think this is the reason why already 3 HL and LM crashed due to SD locked into read only mode after 2 year of work.
Fortunatelly replacing the SD solved the problem but it still be an inconvenience for clients.
Thanks,
Mirco
Thanks,
Mirco
