LM as ModbusSlave. Transaction ID error
I have two LMs and I run one script on them to transfer values from LM via Modbus. On one of the LMs everything works fine, on the second "Transaction ID error". Please help me! I'm still quite a beginner.
The first LM has package  luamodbus 20160606
On the second LM - luamodbus 20190219
if not mb then
  require('luamodbus')
  -- list of coil mapping, starting from 0
  coils = {}
  -- list of register mapping, starting from 0
  registers = {
    {'40/1/5',dt.float32,0},{'40/1/6',0xFF,1}
  holdingRegisters = {
    {'40/1/7',dt.uint16}
  -- list of register data types, element count must match registers table
    -- knx group write callback
  function knxgroupwrite(event)
    local value
    -- try to find matching coil
    for id, addr in ipairs(coils) do
      if event.dst == addr then
        value = knxdatatype.decode(event.datahex, dt.bool)
        mb:setcoils(id - 1, value)
    -- try to find matching holding register
    for id, addr in ipairs(holdingRegisters) do
      if event.dst == addr[1] then
        value = knxdatatype.decode(event.datahex,addr[2])
        mb:setregisters(id-1, value)
    -- try to find matching input register
    for id, addr in ipairs(registers) do
        if (addr[2]==dt.float32) then
          value = knxdatatype.decode(string.sub(event.datahex,1,4), dt.uint32)
        mb:setinputregisters(1+addr[3], value)
            value = knxdatatype.decode(string.sub(event.datahex,-4), dt.uint32)
      mb:setinputregisters(addr[3], value)
            elseif (addr[2]==0xFF) then
  -- coil write callback
  function mbwritecoils(coil, value)
    local addr = coils[ coil + 1 ]
    if addr then
      grp.write(addr, value, dt.bool)
  -- register write callback
function mbwriteregisters(register, value)
local addr = holdingRegisters[ register + 1 ][1]
    if addr then
  grp.write(addr, value, holdingRegisters[ register + 1][2])
  -- knx group monitor, handles group writes
  knxclient = eibdgm:new({ timeout = 0.1 })
  knxclient:sethandler('groupwrite', knxgroupwrite)
  -- modbus slave, listen on all interfaces and default port 502
  mb = luamodbus.tcp()
  mb:open('0.0.0.0', 502)
   --setting slave id is optional
   --mb:setslave(1)
  mb:setreceivetimeout(0.1)
  mb:setmapping(#coils, 0, #holdingRegisters, #registers)
  -- init coils
    value = grp.getvalue(addr)
  -- init holding registers
    value = grp.getvalue(addr[1])
    mb:setregisters(id - 1, value)
-- init registers
    elseif(addr[2]==0xFF) then
      mb:setregisters(addr[3], value)
  -- set callbacks for coil and register write
  mb:setwritecoilcb(mbwritecoils)
  mb:setwriteregistercb(mbwriteregisters)
-- handle modbus and knx
mb:handleslave()
knxclient:step()
Why are you trying to use ModBus for data exchange? You can use KNX/IP routing without any scripts for this.
We will transfer data to a top system that only understands ModBus. LM will work as a gateway.
Strange that the script with data like int16 works fine. Сould you give me the package luamodbus 20160606 for the test?
Which libmodbus (not luamodbus) package versions do you have on both devices?
Yes. Both devices have libmodbus
Tell me the package versions on both devices
on old device 3.1.2-4, on new - 3.1.2-5
"Transaction ID error" - on new device
There are no changes related to ModBus TCP between these versions. Check if you have any errors in the Error Log. TCP slave script has been used by many users an no one reported this error before. This might also be an issue in your top system. If it runs on Windows then you can provide a WireShark dump to see what's causing this issue.
