Creating a KNx point for Modbus Device Communication Error Situation
Hello ,
When we have a communication problem in Logic Machine, In modbus section of LM, modbus device turns red color and we can understand there is a communication problem. I would like to transfer this information as a Bacnet point but I need first , I need to transfer this communication failure in to KNX data point.
How could i do that ?
Regards,
Hi Savaskorkmaz,
I don't know if there is a function for this in the system, but i solved it once with a little resident script.
Put your actions on the position where the logging is now (replace them with your action).
-- Check all modbus meters for connection
query = 'SELECT * FROM modbus_devices'
meter_state = db:getall(query)
previous_state = storage.get('meterstate')
if previous_state == nil then
 for _, device in ipairs(meter_state) do
   if device.active == 0 then
     log(device.name .. " = down")
     log(device.name .. " = active")
 storage.set('meterstate', meter_state)
   if device.active ~= previous_state[_].active then
     log(device.name .. ' is changed to ' .. device.active)
Erwin van der Zwart
For now Erwin's script is the only solution, but we have this feature in our to-do list Smile
Here is a version with writing to KNX objects:
-- Function to send changes to KNX
function writetoknx(name,active)
    if name == 'Meter 1' then  -- name must match modbus device name
   grp.write('1/1/1', toboolean(active))
 elseif name == 'Meter 2' then
   grp.write('1/1/2', toboolean(active))
 elseif name == 'Meter 3' then
   grp.write('1/1/3', toboolean(active))
 elseif name == 'Meter 4' then
   grp.write('1/1/4', toboolean(active))
 elseif name == 'Meter 5' then
   grp.write('1/1/5', toboolean(active))
-- Get meter status
     writetoknx(device.name,device.active)
