13.04.2020, 08:09
admin,
as always all working super!! Big thanks for advices and help!
Alex
Alex
SNMP protocol in Logic Machine
13.04.2020, 08:09
admin,
as always all working super!! Big thanks for advices and help! Alex
As we can now receive bytes in and out 0ver SNMP, how correctly calculate bit/per second from received data? I found very easy calculation method: We can calculate the throughput of an interface using this technique: take a sample of the total bytes-in, wait 60 seconds and take another sample bytes-in total. TotalByteIn [t = 0s] is total bytes-in after 0 seconds TotalByteIn [t = 60s] is total bytes-in after 60 second The average throughput in this time interval is calculated using this formula (the value is Bps) (TotalByteIn [t = 60s] - TotalByteIn [t = 0s]) / 60 = Throughput So 60 here - time in seconds, delay between request of SNMP information. Question - how easier store previous data to calculate BPS (I need received value - last one or previous, or other variant - now and next value after 60 seconds). I tried resident script with time 0, not working but strange - in log showing TX1 and TX2 the same values, but BPS different (in my case I receiving SNMP data every 10 seconds).. TX1 = grp.getvalue('38/5/22') log('TX1', TX1) os.sleep(10) TX2 = grp.getvalue('38/5/22') log('TX2', TX2) BPS = (TX2-TX1)/10 log('BPS', BPS) How better calculate BPS?? BR, Alex
15.04.2020, 06:08
Use storage to store previous object value.
See these examples: https://forum.logicmachine.net/showthrea...6#pid16316 https://forum.logicmachine.net/showthrea...07#pid1707
08.12.2020, 20:31
(04.09.2018, 09:17)AEK Wrote: Hi, as I know, traps are still not supported Hi, I have installed these pakkages, but when running the script it says: Resident script:1: module 'snmp' not found: no field package.preload['snmp'] no file './snmp' no file 'Library snmp' no file 'Library snmp' no file 'Library snmp.so' stack traceback: [C]: in function 'require What am I missing?
09.12.2020, 07:07
Which firmware are you using? Have you tried the latest packages (https://dl.openrb.com/lm-20-imx6/pkg/)?
(09.12.2020, 07:07)admin Wrote: Which firmware are you using? Have you tried the latest packages (https://dl.openrb.com/lm-20-imx6/pkg/)?These versions runs error on install. Running: HW: Wiser for KNX (i.MX6) SW: 2.5.1 (09.12.2020, 07:07)admin Wrote: Which firmware are you using? Have you tried the latest packages (https://dl.openrb.com/lm-20-imx6/pkg/)? hello admin I have LM Lite + Ext SW 20200727 when I try to upload the packages I got :
Best Regards,
11.03.2021, 13:15
You have to install these packages through System config > System > Packages > Add (+) button
11.03.2021, 13:32
(11.03.2021, 13:15)admin Wrote: You have to install these packages through System config > System > Packages > Add (+) button hello admin thank you for your response I upload the packages I use the walk through SNMP code but I get the following error: User script:40: attempt to index global 'snmp' (a nil value) stack traceback: User script:40: in main chunk
Best Regards,
11.03.2021, 13:34
Add require('snmp') at the beginning of your script.
11.03.2021, 14:05
(11.03.2021, 13:34)admin Wrote: Add require('snmp') at the beginning of your script. Thank you admin for your response I got a time out in the log what should I check * arg: 1 * nil * arg: 2 * string: walk failed: snmp: timeout
Best Regards,
11.03.2021, 14:22
This means that LM cannot reach the SNMP device on the network. Check that IP address is correct.
28.10.2021, 17:43
Good day!
Tell me, is it possible to transfer data from the KNX to the SNMP by means of LM so that another client can monitor the data?
29.10.2021, 07:50
18.09.2022, 08:39
Hello
I added the libnetsnmp and luasnmp packages Please see attached image. I used the old HL ,V2.7.0 but When I run my script I got the following errors: Resident script:3: module 'snmp' not found: no field package.preload['snmp'] no file './snmp' no file 'Library snmp' no file 'Library snmp' no file 'Library snmp.so' stack traceback: [C]: in function 'require'
Best Regards,
19.09.2022, 07:33
Go to System Config - System - Packages and press + to install.
19.09.2022, 10:57
(19.09.2022, 07:33)Daniel Wrote: Go to System Config - System - Packages and press + to install. Hello Daniel I have the old Schneider electric HomeLynk but I am using FM-V 2.7.0. I cant find any packages installation option!
Best Regards,
19.09.2022, 10:59
SE does not have this option. Next time buy LM
In upcoming fw snmp libraries will be added. Just wait for a while.
19.09.2022, 11:56
(19.09.2022, 10:59)Daniel Wrote: SE does not have this option. Next time buy LM Great. For Both SE and LM?
Best Regards,
19.09.2022, 13:00
Yes, for both.
