We are starting closed beta testing of our new cloud and Mosaic. Anybody willing to play with it please write here or send a PM and I will send you further instructions. There is new firmware needed for this.
One more thing. We implemented video stream in the cloud. It is not 100% video as we send image snapshots. This will work locally and in cloud without a need to open any ports.
Please do not use high resolution images as LM might struggle with processing it.
Scenes and scheduler are very nice. Same with user access which is very advanced. All these things with mobile apps for iOS and Android and you have good product. One thing which you can only change is BackboneJS into ReactJS and then developing new components will be much easier and nicer
If one day you manage to develop an iOS and Android Mosaic widget to control things without opening the LogicMachine app, along with the new options it will be the definitive system for automation!
Why is new solution so slow compared to old. When i log in, it takes up to a minute to load the values.
When starting page widgets stay there, but values on page takes up to a minute to load.
Can be very irritating for a client?
Hello!
I don't know if issue is on my side or it is a bug but...
When I have example three rooms and I click on room name in menu then I must click somewhere on that room. Otherwise visualisation will not change. This issue is with mobile and tablets. I have not this issue with PC.
Another thing what I found was visibility when I use shourtcut "Add to home screen" with Safari.
In local mode visibility is OK. When using LM remote connection, upper strip is transparent... Couple of images attached.
But afterall I am quite supprised with Mosaic 3.0
Keep up the good work!
(21.06.2021, 23:18)fleeceable Wrote: Hello!
(28.06.2021, 08:52)admin Wrote: Mosaic on remote.logicmachine.net has been updated, see if this fixes the room menu and the iOS home screen issue for you.
(29.03.2021, 08:46)Daniel.I am pleased to play with new Cloud and remote.logicmachine.net Wrote: Hi All
