Visualization for Shutters Control in Mosaic
Hello!
I want to control Shutters in KNX and I don't know which Widget I have to use.
I want to have control same as a KNX push button which means
1. Up/Down Control - 1bit
2. Stop- 1bit
3. Status Up/Down- 1Byte
I have also other options for Status Up and Down Limit
1. Up Limit- 1bit
2. Down Limit- 1bit
Is it possible to use one ready widget or I have to use Widget creator to create one from the beginning?
Thank you in advance
Just click Show all and type shutter
(06.04.2021, 17:11)Daniel. Wrote: Just click Show all and type shutter
OK thank you very much I will try Shutter Vertical and I will tell you if something is not working for me thank you very much once again!
