Hi Pawel,
To be honest, i'm just a early adopter and have never any documentation. By the time the documentation is finished and released i'm already playing with the new stuff (;
I have just as much info as you do, i have all the information from Edgars sample document and by exploring the Apps that are available...
I created some easy commands to give you an idea how to use it:
Run in LUA once to create a file with client IP resolve:
dst = '/www/user/ip.lp'
if not io.exists(dst) then
  io.writefile(dst, '<? print(ngx.var.remote_addr) ?>')
Or if you want to create new and/or overwrite excisting file
and run from custom javascript to get it: inside JS
 $.get( "/user/ip.lp", function( data ) {
    res = data.trim();
    alert('Client IP is: ' + res);
    console.log(res);
or you can test it direct from browser with:
http://192.168.0.10/user/ip.lp
Run in LUA once to create a file with LUA system time table as JSON object:
dst = '/www/user/systemtime.lp'
  io.writefile(dst, [[<?
  require('json')
  require('genohm-scada')
  mydata = os.date('*t')
  mydata = json.encode(mydata)
  print(mydata)
require('json')
print(mydata)
 $.get( "/user/systemtime.lp", function( data ) {
    res = data.trim();
    alert('Systemtime seconds is: ' + res[0].sec);
    console.log(res);
http://192.168.0.10/user/systemtime.lp
Run in LUA once to create a file with get storage script:
dst = '/www/user/storage.lp'
  require('json')
  mydata = storage.get('Sonos_Streams')
  print(mydata)
require('json')
print(mydata)
 $.get( "/user/storage.lp", function( data ) {
    res = data.trim();
    alert('Storage value is: ' + res);
    console.log(res);
http://192.168.0.10/user/storage.lp
Run in LUA once to create a file with get storage script with variable storagename:
dst = '/www/user/dynamicstorage.lp'
  require('json')
  require('socket.url')
  arg1 = socket.url.unescape( getvar('storagename1') )
  arg2 = socket.url.unescape( getvar('storagename2') )
  mydata1= storage.get(arg1)
  mydata2 = storage.get(arg2)
  datatable = {}
  table.insert(datatable, {storage1 = mydata1, storage2 = mydata2})
  datatable = json.encode(datatable)
  print(datatable)
require('json')
datatable = {}
print(datatable)
$.get( "/user/dynamicstorage.lp?storagename1=storage1&storagename2=storage2", function( data ) {
    res = data.trim();
    res = JSON.parse(res);
    console.log(res);
http://192.168.0.10/user/dynamicstorage.lp
Run in LUA once to create a file with get db data script:
dst = '/www/user/database.lp'
  require('json')
  require('dbenv')
  db = dbenv:new()
  query = 'SELECT * FROM objects'
  mydata = db:getall(query)
  print(mydata)
require('json')
require('dbenv')
db = dbenv:new()
print(mydata)
$.get( "/user/database.lp", function( data ) {
    res = data.trim();
    console.log(res);
http://192.168.0.10/user/database.lp
You can also use require('user.yourlib') and use the funtion like we used to in LUA, this way if someone opens the .lp file he can't see te functions behind it, only the function call.
Deleting .lp can also be done with LUA:
os.remove("/www/user/ip.lp")
os.remove("/www/user/systemtime.lp")
os.remove("/www/user/storage.lp")
os.remove("/www/user/dynamicstorage.lp")
os.remove("/www/user/database.lp")
or directly from APPS FTP folder User
