23.08.2021, 14:55
An information but doesn't widget creator work on new cloud?
BR Cristian
BR Cristian
Widget creator
23.08.2021, 14:55
An information but doesn't widget creator work on new cloud? BR Cristian
23.08.2021, 14:59
WC is used locally and what is created is sent to cloud as before.
23.08.2021, 15:04
23.08.2021, 15:05
It is probably cache. If you still will have problem we need a way to reproduce.
23.08.2021, 15:06
23.08.2021, 15:08
Ok but still describe what should I look for.
23.08.2021, 15:24
(This post was last modified: 23.08.2021, 15:25 by CristianAgata.)
(23.08.2021, 15:08)Daniel. Wrote: Ok but still describe what should I look for. In the widget_priority, I pass a number from 0 to 8, with a group address to KNX BUS (1 byte object). Local works in the cloud as Status I have always 0. In the widget_setting, I pass voltage (2 byte float), cosf (1byte integer) value as number and the other three as select box (1 byte integer). The behavor is the same Local works but in the cloud all white spaces. In the widget_thermostat doesn't works the status of push button and the select value. Let me know if you need more info. BR Cristian On the old cloud works fine.
23.08.2021, 15:39
23.08.2021, 15:47
(23.08.2021, 15:39)Daniel. Wrote: Works for me. Attached
23.08.2021, 15:47
I meant the whole project not just mosaic. Send to PM
Tired your backup and all works fine. Do you use RC2 2021? https://www.screencast.com/t/NQPRwqRscvfQ
01.09.2021, 07:38
(23.08.2021, 15:47)Daniel. Wrote: I meant the whole project not just mosaic. Send to PM Hi Daniel, It seems I have the same problem as well. I mean that status object of 2 elements (temperature and menu list) of a widget creator are set to 0 even if KNX status object is not 0. It does not happened immediately. I notice this after a couple of days especially when during that period knx status objects do not change. BR
01.09.2021, 08:15
Can you send me your cloud username, network ID and which objects are not working via PM. Which firmware are you using?
06.09.2021, 08:33
06.09.2021, 08:34
I've seen it, thanks. We are currently looking into this issue.
15.09.2021, 17:02
15.09.2021, 17:04
We made some changes. Have you seen this issue again?
15.09.2021, 18:32
01.02.2022, 12:52
I have small new feature idea:
Tabs - a possibility to prepare different tabs which could be visible based on simple conditions or specific value or no controlled by value but by user swipe. Both controlled and not controlled could be helpful. Controlled e.g. to show only what is important in current widget state. E.g. complex heating controller could show only on/off switch when it is switched off. But in some cases it could be good to have a possibility to prepare a few separate screens for on widget which could be changed by user swipe.
Done is better than perfect
