Auto-opening widget after loading the page
Hi I'm constantly trying to find a solution; automatic loading of the widget after loading the page. I found js code on the forum that uses the page id (currentPlanId) and the widget id. Unfortunately it doesn't work properly on my page:
https://forum.logicmachine.net/showthrea...idget+open
Maybe someone knows how to write code that automatically opens the widget after the page is loaded?
You should not be using widget for this only two plans and the floor plan directly on it. If you use Pietro and Parter as links with icon and active icon you will get exactly what you need.
Add this to Custom JavaScript. Add widget-autoopen class to the button that will be clicked when the plan is shown.
$(function(){   function showWidgets() {     $('#plan-' + currentPlanId).find('.widget-autoopen').trigger('vclick');   }      $('body').on('showplan', showWidgets);   showWidgets(); });
(03.09.2021, 07:41)Daniel Wrote: You should not be using widget for this only two plans and the floor plan directly on it. If you use Pietro and Parter as links with icon and active icon you will get exactly what you need.
Yes, you are right, Thanks!
(03.09.2021, 07:47)admin Wrote: Add this to Custom JavaScript. Add widget-autoopen class to the button that will be clicked when the plan is shown.
Works fantastic, thank you very much!
