querystatus & queryactual -> rx error
LM5 -> DALI RS485 gateway -> Lamp
HW: LM5 Lite + Ext (i.MX6)
SW: 20190904
require('user.dali') res, err = dalicmd (2, 'arc', {addrtype = 'short', address = 0, value = 30}) log(res, err) sleep(1) res, err = dalicmd (2, 'queryactual', {addrtype = 'short', address = 0}) log(res, err)
test 06.10.2021 19:54:45 * arg: 1   * bool: true * arg: 2   * nil test 06.10.2021 19:54:46 * arg: 1   * nil * arg: 2   * string: rx error
What could be the problem?
Tried deleting user.dali and rebooting, didn't help.
Если можно на русском, лучше на русском.  Smile
RX error usually means a collision. It can happen if you have several ballasts with the same short address.
(07.10.2021, 06:19)admin Wrote: RX error usually means a collision. It can happen if you have several ballasts with the same short address.
It's a good idea about collisions, maybe the contractor has set up the lamps in this way.
I will ask him about it, or I will reconfigure everything.
Thanks!
