User ACL and Holiday scheduler
I have a problem with a HL and user setup as partial view of Scheduler. The Holidays doesn't Appear since I upgrade to 2.6.0 and now to 2.6.2.
It was displaying in 2.5 version
When I try to setup the partial ACL in user tab, I can select the holiday, then save. But when I come back it has disapear.
Only way to edit the user-acl table and add
user - scheduler - 1
in table directly on the DB
Do you have this problem ?
SE ECO EXPERT
Clear browser cache and try again.
(02.11.2021, 15:57)Daniel Wrote: Clear browser cache and try again.
I tried Big Grin
I tried with Edge, firefox, chrome too.
My script Work,:
db:insert('user_acl', {
  user_id = 1,
  module = 'schedulers',
  item_id = 0,
I can see the holyday checkbox checked, but still no holyday displaying when login with the user. However with admin, no problem, or if I set the user to full.
Here when logging with admin:
I tried in English and french (try some kind of hings). And here after my script, but still no Holiday:
After script, it's checked
When logging with the user:
What is also strange, if I go back to user tab and edit, then save, the checkbox disapear also !
Here with the admin login:
SE ECO EXPERT
Bug confirmed, thanks. We are working on 2.7.0 should be mid December.
Yes no problem. If patch don't hesitate to pm ;-)
SE ECO EXPERT
You need to reload the web server after the db query. ACL is cached, reloading the web server updates this cache.
os.execute('/etc/init.d/nginx reload')
