07.03.2022, 07:40
Status won't work without a profile. Can you post a screenshot of device info? Click (i) button in the device list.
Zigbee gateway integration
07.03.2022, 07:40
07.03.2022, 12:00
(07.03.2022, 07:40)admin Wrote: Status won't work without a profile. Can you post a screenshot of device info? Click (i) button in the device list. Is it this?
07.03.2022, 12:07
Thanks, we will add this device. You will have to reset it and pair again after installing the new ZigBee app version.
07.03.2022, 12:10
13.03.2022, 11:37
Hi Admin,
I'm testing several device (ikea) in zigbee all works fine with the app. I added the group address but in cmd all work in read doesn't? Could be because I'm using virtual groups? Devices are: - Socket TRADFRI - Lamp TRADFRI LED In the attached file the info. Best regards Cristian
14.03.2022, 10:25
What do you mean by "in cmd all work in read doesn't"?
14.03.2022, 11:06
21.03.2022, 13:38
We've checked the control outlet and the status reports did not work with older outlet firmware. It works with newer firmware but unfortunately we do not support firmware upgrades for Ikea devices at the moment. The upgrade can be done with Ikea Tradfri hub.
02.04.2022, 08:48
Hallo,
is there a place to read the changelog of the updated Zigbee app and a list of supported devices? I've seen it has been recently updated but I don't knoe is and what devices are now supported. I'm willing to move my zigbee network from zigbee2mqtt to LM, but I have few devices unsupported - Eurotronic Spirit TVR - Mi / Aqara PIR - Mi/Aqara reed sensors - Mi/Aqara LUX sensor - some other IKEA 200v powered devices what I cannot move since they act as router ![]() thanks regards M
02.04.2022, 16:02
03.04.2022, 19:11
Hi.
I have 5 ligthbulbs who is not updating status for on/off or dim levels. I have correct datatypes, and everything else seems ok. When i in zigbee app opens the control and status window for the device and push read the status and dim levels is read ok. But the group adresses is not updated. All light is namron bullbs, 3 of them is dimmable and 2 of them also have color control (cold/warmwhite), Color control seems to be missing in the profile of model 3802961 (endpoint 768?) Manufacturer: Namron AS Model: 3802960 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - HaDiagnostic (2821) - LightLink (4096) - 64642 Output clusters - Time (10) - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPwr (33) --------------------------------- Manufacturer: Namron AS Model: 3802961 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - LevelCtrl (8) - LightingColorCtrl (768) - HaDiagnostic (2821) - LightLink (4096) - 64642 Output clusters - Time (10) - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPwr (33)
03.04.2022, 19:44
I think i need to follow up on post #110 #111 #119 in the search for a solution for getting the Develco on/off plugs working.
There have been several updates to the zigbee app and none of them have sorted out the missing ability to control them og retriving status from them. I understand the powermetering function is not ready, but it shoud be possible to get them working in means of control. I have reset the devices several times and re-included them to the zigbee network in hope for a soulution for getting them working. Manufacturer: Develco Products A/S Model: SPLZB-131 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 2 Profile: 260 Input clusters - Basic (0) - SeMetering (1794) - Identify (3) - Alarms (9) - HaElectricalMeasurement (2820) - OnOff (6) - Groups (4) - Scenes (5) - DeviceTempCfg (2) Output clusters - Basic (0) - Ota (25) - Time (10) - Identify (3) - MsOccupancySensing (1030) Endpoint 1 Profile: 49353 Input clusters - Scenes (5) - OnOff (6)
05.04.2022, 11:11
@clue9, you didn't mention that the full manufacturer name for this device is "Develco Products A/S" so the previously added profile did not work for it. The next version will have this fixed.
05.04.2022, 11:19
@emme, support for most Ikea devices has been added recently. We have Eurotronic Spirit TVR at our office but it's buggy so we decided not to support it at the moment. Some Aqara devices have non-standard behavior so it complicates things and takes longer to implement.
@clue9, profiles for these lamps will be added in the next build. You will have to reset them and pair again.
05.04.2022, 14:10
Could you please add support of this device?
Code: Manufacturer: frient A/S
13.04.2022, 14:21
Hello.
Is SONOFF ZigBee 3.0 USB Dongle Plus with a Z-Stack coordinator (CC1352P2_CC2652P_launchpad_*.zip v 20220219) supported out of the box with Zigbee app v20220322? Zigbee has a red dot in the status bar. As I understand, that dongle uses a different serial port /dev/ttyUSB0 (instead of /dev/ttyACM0 for CC2531). Is it possible to change the port or modify the Zigbee app configuration programmatically? Thank you in advance! HW: LM5 Lite + Ext (i.MX6) SW: 20211215 | Serial port list with a connected dongle /dev/ttyUSB0 ITead - Sonoff Zigbee 3.0 USB Dongle Plus Code: Apr 13 13:00:57 LogicMachine kern.info kernel: [ 241.041921] usb 1-1: cp210x converter now attached to ttyUSB0
14.04.2022, 12:44
Our new ZigBee interface is based on a similar hardware but it has a different USB product id which app uses to detect the adapter. You can try changing the product id from ea60 to bee0 on Linux using this tool: https://github.com/DiUS/cp210x-cfg
Keep in mind that this a write-once operation so double check everything before changing the parameter.
18.04.2022, 11:24
(14.04.2022, 12:44)admin Wrote: Our new ZigBee interface is based on a similar hardware but it has a different USB product id which app uses to detect the adapter. You can try changing the product id from ea60 to bee0 on Linux using this tool: https://github.com/DiUS/cp210x-cfg Thank you, everything works fine! P.S. Device is based on a new CP2102N-GQFN28 chip. CMD tool working code is https://github.com/ilutchenko/cp210x-cfg...id-pid-set
Is the new zigbee usb stick (with external antenna) already up for purchase and if so can I order one. Best Regards, Tigi
20.04.2022, 08:20
We have fully working prototypes at the moment. Production devices should be ready in two months or so.
