URL redirect not working on LM
Hello:
I have a LM installed which I want to access from the Internet. For that purpose I put the port 60080 in the HTTP Server section, and I redirected the port 60080 to 60080 from outside in the firewall. (i tried with the default 80 port also).
I made an attemp to connect from the outside but it failed, and I don't know why. I have other redirection with the CCTV cameras, and it works. It's true that it's my first time with a LM, but I made a lot of redirections with homelynks.
What could be happening?
Thanks in advance.
HL and LM are identical here. Use zerotier for remote connection. No need to open any ports.
https://openrb.com/zerotier-remote-maintenance-of-lm5/
(10.03.2022, 15:59)Daniel Wrote: HL and LM are identical here.  Use zerotier for remote connection. No need to open any ports.
Thank you Daniel. Today I'll try a installing HL instead the LM, to rule out if it is a software or network problem.
