31.03.2022, 09:45
For an error I deleted my LM5 device from zerotier as I can add it manually
Thank you
Thank you
zerotier add manual lm5
31.03.2022, 09:45
For an error I deleted my LM5 device from zerotier as I can add it manually Thank you
31.03.2022, 09:55
Run this script, this will give you node ID which you can use in Zerotier to add manually
Code: info = io.readproc('zerotier-cli -D/var/lib/zerotier-one_default/ -j info')
Ctrl+F5 (31.03.2022, 09:55)Daniel Wrote: Run this script, this will give you node ID which you can use in Zerotier to add manually I have add manually in my zerotier net but not work stay in waiting ip, correctly detects that the network is private but does not proceed. Best regards
01.04.2022, 14:46
I just tried the same and it worked fine for me. Maybe try again and reboot LM.
Ctrl+F5 |
