06.04.2022, 09:10
Guys, Please why the CPU/IO value is in red color?
See the attachment
See the attachment
					CPU/IO
		06.04.2022, 09:13
		Some process takes to much time to run on the CPU. Install System load app and check which process is so hungry and then try to solve it.
		06.04.2022, 09:22
	(06.04.2022, 09:13)Daniel Wrote: Some process takes to much time to run on the CPU. Install System load app and check which process is so hungry and then try to solve it. Thanks for the quick reply Daniel, What usr stands for?
		06.04.2022, 09:36
		Please install System Load app instead of the Process as this one is not to accurate.
		06.04.2022, 09:38
		06.04.2022, 09:46
	(06.04.2022, 09:39)Daniel Wrote: Here Thank you, Please see the attachment, It looks normal, isn't it?
		06.04.2022, 09:49
		Yes, disable KNX IP and see if this makes any difference.
		06.04.2022, 13:17
		06.04.2022, 13:22
		Did you monitor the System load app for a longer while? Anything changing?
		06.04.2022, 13:25
		06.04.2022, 13:26
		Try disabling all the scripts, sync and reboot.
		06.04.2022, 13:32
		08.04.2022, 06:21
	(06.04.2022, 13:32)Fahd Wrote:(06.04.2022, 13:26)Daniel Wrote: Try disabling all the scripts, sync and reboot. Hi Daniel, It is because of the scripts, I have 4 scripts like this one below, and I will have more, what is the problem with it? it is event-based on Tag Code: value_1 = grp.getvalue('14/0/12')
		08.04.2022, 07:42
		If you did tag grp 32/1/3 then you have a loop.
Ctrl+F5  |
